Lowering
Tezzax5
Lowering
Postby Tezzax5 » Tue Sep 16, 2008 9:02 am
AZNTieN wrote:Alright
So I've been wanting to lower my NB8A for a while now
But I want to still be legal height (I heard it was 100mm clearance)
does that 100mm clearance include the plastic under tray under my engine?
I'm looking at Tein Super Street Coil Overs
Is it worth the $$
And whats the best price you've gotten on these in Brisbane
Have a chat to NMX516 or spyvspy as both have SS fitted in fact it was NMX516 that convinced me to spend the dosh.
Coming from bilstein's with less than 75k on the clock to SS was an absolute relevation.I actually want to drive the car more than 2 hours at a time.I know i could of done things cheaper but i got the edfc with it.Nice and soft round the burbs and the ability to firm things up when curves appear...
Ask some the Brisbane NB guys to take you for a spin......You will be impressed
Like the people here have said...Do it once do it right.
Sasso
Lowering
Postby Sasso » Tue Sep 16, 2008 8:28 pm
Get tein SS, Gavin and Marcusus both have them and I've riden in their cars and its fantastic. In gavins nb8b we tested out the stock shocks on a bumpy road and a twisty rd, then got the teins installed and did the same thing (with factory tein settings) and we seriously couldn't tell the difference, except that he scraped going out of mania's drive way (sharp), and his car looks so much better. It felt so planted in the corners (pie in the sky road) but it didn't roll as much.
Also if you buy full coilovers then the suspension travel doesn't reduce because the shocks are shorter. And its not such a big deal going below 100mm at some points, as long as you don't scrap too often and its not completely obvious and dragging on the ground. Mine is 100mm to the jack points on the side, i dont really scrape much at all unless you forget to slow down on a speed bump. The butterfly brace is now a little lower than the jack sills.
Ride height is usually measured from wheel centre to the guard, so for refference mine is 300mm, ie, about 12". Had no trouble with policemenofficers even on P plates.
TieNN89
Lowering
Postby TieNN89 » Tue Sep 16, 2008 9:30 pm
aww now all i need is the $$
i guess if i get coilovers i can have them down low or 4x4 height if i wanted too :)
now my stupid question is with the tein ss installed am i able to adjust them up to stock height?
before i start dreaming on about having coil overs
am i right to say
having them i'll beable to adjust
comfort levels - stiff or soft
i know the stock gear is pretty nasty on the back especially on those aweful roads we traveled on on Sunday so will I beable to adjust it so when I'm dailying that its a much softer ride?
So If i have the setting on stiff = less body roll soft = more body roll?
now with height adjusting
How much higher than stock height and how much lower than stock height can I go?
TieNN89
Lowering
Postby TieNN89 » Tue Sep 16, 2008 9:33 pm
Tezzax5 wrote:I actually want to drive the car more than 2 hours at a time.I know i could of done things cheaper but i got the edfc with it.Nice and soft round the burbs and the ability to firm things up when curves appear...
just wondering How fast does it take to adjust from soft to stiff
Tezzax5
Lowering
Postby Tezzax5 » Tue Sep 16, 2008 9:55 pm
Press a button and the car transforms in seconds..... :mrgreen:
Source the SS here in brissie(don't forget qld mx5 club discount) and buy the edfc overseas.. :wink:
And yes i'm just below stock height..
And if you ever upgrade to one of those hairdryer powered nb's you can take the setup with you...Just don't throw the old suspension out....
marcusus
Lowering
Postby marcusus » Tue Sep 16, 2008 10:29 pm
philz wrote:Do it once do it right.
Amen! It's silly doing something like upgrading springs, then upgrading shocks, only to find out you want to get coilovers. What a waste of time and money. Research everything correctly, assess everything impartially, and just do it right from the get go.
AZNTieN wrote:now my stupid question is with the tein ss installed am i able to adjust them up to stock height?
Yes. You can probably go higher if you wanted to. The Teins come set at I think the lowest legal height (refer to what Sasso said re distance between wheel centre and guard).
AZNTieN wrote:am i right to say
Yes. When you adjust the coils, what you're doing is adjusting the fluid flow rate inside the shock. When you "stiffen" the shocks, you're actually restricting the amount of fluid that can move from one part to the other. When you "soften" them, you're allowing more fluid to flow.
AZNTieN wrote:i know the stock gear is pretty nasty on the back especially on those aweful roads we traveled on on Sunday so will I beable to adjust it so when I'm dailying that its a much softer ride?
Yes. That's what I do. Currently I've got my SS set to softest at the front, and one off the softest on the rear. That's what I use as my daily settings. In all honesty, for spirited runs, I haven't changed it off these settings. It's only when I go to the track that I bother to adjust it to full hard. However, the main reason for this is purely because accessing the rear coils is a bit more of a mission than the front coils (accessing the rears involves removing the fuel line panel and the boot trim). If I had easy access, or an EDFC, I'd probably adjust them a lot more frequently.
AZNTieN wrote:So If i have the setting on stiff = less body roll soft = more body roll?
Correct. That being said, the "more body roll" is completely a relative measure. I think even the softest setting is stiffer than the original shocks/springs. That being said, I don't remember what happened last week, let alone what the stock suspension felt like in December last year when I replaced them.
AZNTieN wrote:How much higher than stock height and how much lower than stock height can I go?
No idea how much higher you can go, but why would you want to?
As for how much lower, I had it pretty bloody low when I got them. So much so in fact that I raised it back to the Tein factory settings, which is the wheel to guard measurement that's been mentioned before.
In short, I would say "more than enough" in both cases.
Sasso
Lowering
Postby Sasso » Tue Sep 16, 2008 11:27 pm
Its not just body roll it affects, its the rate of body roll, and the balance front to rear, and balance at different stages in the corner to adjust the load transfer which affects understeer/oversteer.
On a long corner the car will roll the same amount assuming it reaches steady state, spring and sway bar stiffness affect roll more.
Dampers really aren't simple things, you'd have to read up on it to use it properly. Or just buy it and use it for basic things, hoping whoever designed them knew what they were doing.
Don't get hard springs on soft dampers and vice versa, they are carefully matched, so stock shocks work well with stock springs and thats all, which is why coilovers are good because they are designed to go together.
TieNN89
Lowering
Postby TieNN89 » Wed Sep 17, 2008 12:20 am
so i can adjust it so its more comfortable than the stock gear?
Sasso
Lowering
Postby Sasso » Wed Sep 17, 2008 12:43 am
Yes. If you read what he just said before "When I replaced my stock shocks with the super streets, the comfort level increase was huge, and that was with the shocks set about midway between soft and hard. Now that I've got them on full soft, it's even better, and I haven't noticed a compromise in handling when driving about normally on the streets."
Unless you're looking for a drastic stance (visual) or track performance improvement, I wouldn't bother blowing 2 grand on suspension, its a waste of money if you just want a softer ride, the stock shocks should be comfortable enough, if not, buy a rollz.
You need to tell us what exactly are you trying to get out of lowering your car so we can help you pick the right solution. Don't buy just because, 2 grand is a lot of money to make the car an inch lower.
Lowering
Postby sliq » Wed Sep 17, 2008 1:45 am
AZNTieN wrote:So I've been wanting to lower my NB8A for a while now
like i said earlier, just get what you need and go with the springs.
philz
Wheel guru
Lowering
Postby philz » Wed Sep 17, 2008 1:57 am
dude, have you read anything that has been said?
Sure you can get springs, but with coilovers you can independently adjust them to your liking.
If you get for example king springs, it's at a set height.
It's either gonna be too low or too high/stock height.
Not only is it about lowering, getting springs that aren't accustomed to the shocks will mean a sh*t ride, and might even make your mx5 handling worser than stock.
Coilovers will transform your car's handling. to great > even greater.
Also if you want to reduce body roll, suspension will decrease it. But if you want better results get thicker swaybars.
Sasso
Lowering
Postby Sasso » Wed Sep 17, 2008 11:42 pm
What phills said minus the spelling mistakes lol. :wink:
Lowering
Postby sliq » Thu Sep 18, 2008 12:31 am
:roll: :roll: :roll:
wun911
Lowering
Postby wun911 » Thu Sep 18, 2008 12:32 pm
I think he has to take an NB with SS for a drive, some think like comfort you just cant explain.
If your short on coin install them yourself, get jap spec ones, and forget about EDFC.
If pockets not deep enough, would rather have Tein basic than a mixed bag of springs and shocks.
every ounce counts
Adam_NAclubman
Lowering
Postby Adam_NAclubman » Thu Sep 18, 2008 12:46 pm
Stance. They go lower
Users browsing this forum: No registered users and 125 guests
