Speedbleeders leaking
mitch_f1
Re: Speedbleeders leaking
Postby mitch_f1 » Thu Jul 21, 2011 10:55 am
Is it normal for a little bit of fluid to be coming out of the nipple when you are bleeding the brakes, just out of interest?
Sorry for the ancient revivial.
Postby Okibi » Thu Jul 21, 2011 11:43 am
When you bleed the brakes you're draining the old fluid out of the nipple, so there should be more than a little fluid coming out the nipple.
Do you mean the thread of the nipple? As long as it doesn't leak at all when the nipple is tightened (and don't be an idiot like me and snap the nipple in the calliper) then your all good.
You have speedbleeders or OEM?
mitch_f1
Postby mitch_f1 » Thu Jul 21, 2011 9:19 pm
I have closest to OEM (my OE ones were a bit corroded, and the OE ones are like $20 a piece or something rediculous). But yes, it is from the thread and only when bleeding
DaveWA
Vehicle: 10AE
Postby DaveWA » Fri Jul 22, 2011 5:48 am
replacement bleeder nipples, I have an extra 2 for the front...brand spankers....
pls note front and rear can differ
and no didnt snap em...looks like the fronts
were stripped in a former life
