sportmax wheels - anyone used them
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Aug 14, 2008 10:01 am
these are only going to be a street wheel so they will not get that much of a workout. stay tuned for when they come in.
RG.net
Postby RG.net » Thu Aug 14, 2008 8:55 pm
who did you end up going through 16bit? JDM will be dropping their prices soon, so i have been told.
RG.net
Postby RG.net » Thu Aug 14, 2008 8:58 pm
Adam_NAclubman wrote:Image
Thats an 8 +12 with pulled guards, 8 +0 Sportmaxx would sit even further out
8.5 +6 (sits the same distance out as an 8 +0) with reasonably stock guard, but it was still sitting on the jack, so I guess they'd tuck in a bit more but you still need to pump the guard a heap to get them in neatly I think
ADAM! what a tease!!! show us some shots of those jems!
what tyres you running, is there any scrubbing etc and how much lower is your can from stock
Adam_NAclubman
Postby Adam_NAclubman » Fri Aug 15, 2008 12:52 am
They're not Sportmaxx's, just wanted to show a similar offset since people were wondering how they'd fit
My car is looow. Not as low as it could go, but I wouldnt want to drive it any lower on the street
16bit
Postby 16bit » Fri Aug 15, 2008 2:22 pm
I should have my new combo in about a month - you will just have to wait and see.
Sheck
Postby Sheck » Sat Aug 16, 2008 10:19 pm
just want to add that those pics are with no camber as the car is up in the air, they'll tuck in quite a bit when the car is back on all 4's
at least that's what it looks like, if you can correct me please do
Sasso
Postby Sasso » Sun Aug 17, 2008 4:49 pm
Adam_NAclubman wrote:They're not Sportmaxx's, just wanted to show a similar offset since people were wondering how they'd fit
Fitment looks good.
Whats your centre to fender distance?
Adam_NAclubman
Postby Adam_NAclubman » Sun Aug 17, 2008 5:41 pm
No idea, I had it fairly even all round before I started rolling the guards but now I need to set them all again as I had to extend the coilovers to get the guard roller in, then when I brought them back down I dont think I got them even again
fundies
Postby fundies » Mon Aug 18, 2008 3:39 pm
http://cgi.ebay.com.au/SPORTMAX-002-513 ... dZViewItem
I got the 9.5kg weight from this ad. Maybe its a slightly different style sportmax, hence, extra weight.
16bit
Postby 16bit » Mon Aug 18, 2008 5:34 pm
spokes are quite a bit thicker so probably correct.
16bit
Postby 16bit » Mon Aug 18, 2008 5:36 pm
what size tire are you using?
Adam_NAclubman
Postby Adam_NAclubman » Tue Aug 19, 2008 1:17 am
195/45/15 front, 195/50/15 rear
16bit
Postby 16bit » Tue Aug 19, 2008 9:45 am
sh*t me they tyre stretch a bit. would that compromise handling?
Sheck
Postby Sheck » Tue Aug 19, 2008 3:25 pm
streching the tyre makes the sidewall stiffer, so it should make handling better
marvis
Postby marvis » Tue Aug 19, 2008 6:34 pm
+ 1
But you need a bit of flex to grip, good on the back if you slide.
Users browsing this forum: No registered users and 248 guests
