whats left to do
Steampunk
Postby Steampunk » Tue Jun 17, 2008 3:50 pm
wun911 wrote:driving without clothes on ... the list can go on and on hey Wun
Photos of DECA, its easy to tell who I am...
:shock: Do I dare look? :|
RG.net
Postby RG.net » Tue Jun 17, 2008 9:41 pm
or has already achieved it!
like i said just chuck those swaybars in before you decide on blowing your dosh on something, when you might be satisfied the way it is.
MxJadeMonkey
Postby MxJadeMonkey » Tue Jun 17, 2008 10:02 pm
25 is too big for a road going NA6 for a front sway, IMHO!
usually a 3 way adjustable 22 or even 24 for front, and 16 or 18 for the rear,
I fell maybe an understeer issue creeping in if any bigger, doubt that you will run the 25mm on hard.
Also if you run the front with out the rear, make understeer your new best friend for medium speed or above cornering.
just my 2c, no offence intended, a 25mm should be ok on soft.
1991 NA6 Velocity Blue (Ford Colour)
Steampunk
Postby Steampunk » Wed Jun 18, 2008 9:34 am
x2 to what Josh stated.
Soft front setting, and soft rear setting to start off with young man.
muzza2
Postby muzza2 » Wed Jun 18, 2008 9:54 am
probably,
but for $50 for the 2 bars, i wasnt going to pass them up!
and i've just aquired a roll bar...
so im well on the way to my \"goals\" :lol:
kitkat
Postby kitkat » Wed Jun 18, 2008 10:06 am
get rid of the shitty VLSD diff and get a TorSen...
Other than the normal handling mods the only other thing you can do is work on learning the car... understand how it reacts in certain situations, how to control it and how to get the most out of it without going over its limits.
Driver > Car
Alex
Postby Alex » Wed Jun 18, 2008 1:00 pm
noone seems to have mentioned playing around with tyre pressures yet
I would put that on the list as well
Damo
Postby Damo » Wed Jun 18, 2008 6:50 pm
SM wrote:noone seems to have mentioned playing around with tyre pressures yet
Definitely! If you're after feel, then tyre pressures and a wheel alignment will give you the best bang for your buck by a country mile. The recommended 26PSI is useless for the tyres I've tried. My wheel alignment and upped tyre pressures transformed the car.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
