Veloce wrote:Terry
This looks like a good setup. I have a set of Bilsteins from a Clubbie needing to be rebuilt. Where did you source the springs and what spec were they?
Who did the mods to the Bilsteins (perch) and what were the final specs (changes) to the revalving?
I am on the Northside too any chance of feeling what the final ride is like?
Rob
tbro wrote:Rebuild the Bilsteins, re-valving to a softer valving at lower speeds and increasing rebound.
Noodle wrote:tbro wrote:Rebuild the Bilsteins, re-valving to a softer valving at lower speeds and increasing rebound.
What was your reasoning for these changes?
Would you happen to have your final shock dyno graphs?
Also what were the spring rates of the springs you're running?
tbro wrote:Noodle wrote:tbro wrote:Rebuild the Bilsteins, re-valving to a softer valving at lower speeds and increasing rebound.
The reason for changing suspension was pretty straight forward, my Truck when empty rides smoother than the clubman![]()
And I'm not joking.
Fatty wrote:terry,
i've ben trying to buy some nb shockmounts from fatcat but they won't reply to my emails![]()
how did you find them to deal with?
