18'' rims on a MX5
Boags
Postby Boags » Fri Oct 19, 2007 6:35 pm
bruce wrote:
Caedrus wrote:
From inside the car, they suck ass like a nuclear powered ass sucking machine.
:lol:
:lol: :lol:
irwin83r
Postby irwin83r » Fri Oct 19, 2007 9:34 pm
legality wise im not so sure they are a problem...
correct me if im wrong but isnt the rolling dia the only thing they are concerned with not the rim dia..
meaning if you up size the rim you will have to lower the profile of the tyre to retain.../stay in the maximum change of rolling dia of 3%...
as far as width and track go they can only increase by 1\" or 25mm.
so... going by that (if im right) you can go as big as you like providing you can find rubber with a lower enough profile to keep it down in rolling dia.,
Postby bruce » Mon Oct 22, 2007 12:11 pm
No, I'm pretty sure it's rim size. I don't think they are concerned with diameter as it would be too hard to check (plus all the different profiles available would cause too much confusion).
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Oct 22, 2007 12:42 pm
in qld i am pretty sure its up 2 inches only going down 5 series each inch.
JBT
Postby JBT » Mon Oct 22, 2007 12:54 pm
Qld rules are here.
meanmx
Postby meanmx » Mon Oct 22, 2007 7:07 pm
Do what you want wheel wise. There are a lot of people on here that are fanatical about not going any larger than 16 although 15 would be better. I personally have 17's on my NA and I wouldn't swap them. As long as the wheels are light the impact will be minimal although there will be some issues with going heavier rim. Up to you to decide whether you want that or not. 18's will definately fit your car though and will look awesome in my opinion.
Ben
2014 VW Mk7 Golf R
irwin83r
Postby irwin83r » Mon Oct 22, 2007 8:06 pm
bruce wrote:No, I'm pretty sure it's rim size. I don't think they are concerned with diameter as it would be too hard to check (plus all the different profiles available would cause too much confusion).
theres a simple equation to work it out (though it escapes me) but more so i thought the reasoning behind this was to do with sending your speedo out..
if the rolling dia stays the same so dose the speedo reading... any link to NSW rules??
Charlie Brown
Postby Charlie Brown » Tue Oct 23, 2007 9:21 am
http://www.rta.nsw.gov.au/registration/ ... 9_rev4.pdf :D
StanTheMan
Postby StanTheMan » Tue Oct 23, 2007 9:27 am
NSW
every state is a little different. I stumbled across SA one last night.....very detailed with cars before a certain manufacture date are not affected by offset. provided the tyre doesn't foul against anything & so on.
but personally it annoys the hell out of me when peeps start stating misinformation when its obvious they have never looked at this information.
This subject comes up every 6 mths everytime some clown thinks 1 inch up & 1 inch wider is all you are allowed or something similar.
OK if you know you are breaking the rules ....its your call. you are the one who may get defected. but most of us who have modded will most likely get defected in one way or another. I think we should ad these docs in a sticky for all the states to compliment the info we have now on suspension modifications thanks to MX5 racing
/off box
/rant
:mrgreen:
Ajay
Postby Ajay » Tue Oct 23, 2007 11:55 am
without looking at my tyre plaque cause im at work.. what size are the standard rims.. i know they are 14\" but what is the tyre size
Ajay
Charlie Brown
Postby Charlie Brown » Tue Oct 23, 2007 12:19 pm
mx5_boy wrote:without looking at my tyre plaque cause im at work.. what size are the standard rims.. i know they are 14" but what is the tyre size
Ajay
185x60x14 on 5.5" rims to '93
Garry
Postby Garry » Tue Oct 23, 2007 1:10 pm
185x60x14 on 5.5\" rims to '93
I'm so old that I remember when 60 series tyres were considered \"low profile\" tyres..... *sigh*
StanTheMan
Postby StanTheMan » Tue Oct 23, 2007 1:29 pm
I'm so old that I remember when 60 series tyres were considered "low profile" tyres..... *sigh*
ROFLMHO
Postby bruce » Tue Oct 23, 2007 2:19 pm
I used to think Momo Stars in 16 inch looked so good on a Dunny-door (they still do!). 50 profile tyres- wowsers.
GP
Postby GP » Tue Oct 23, 2007 4:37 pm
My XU1 came with Low profile 70 series tyres on it :lol:
Graham
