AutoExe Coilovers... anyone know?
- bruce
- Vehicle: NA8 - Turbo
- Mr Starlet
I got Jap SS for a really good price, mine had 6kg/5kg front/rear springs so not harsh at all. Personally I think harness is in the spring, the dampers if tuned right should simply steady the springs from oscillation and shouldn't be use to firm up the springs. I heard of Teins Flex and possibly SS with 7kg/6kg springs, I would imagine these having less body roll but at the same time significantly rougher on bumping Aussie roads.
I would also suggest main stream be the wiser choice, PSS9 if you could afford, otherwise, Tein Flex, SS, Koni, KYB AGX....in that order. If you're not building a track car then I don't really see the point of going higher than Tein SS, slap on Tein EDFC and you'll find your sweet spot real quick.
Good luck
Minh
Good luck
Minh
