Tein rattles
Re: Tein rattles
Postby manga_blue » Mon Aug 25, 2014 4:58 pm
bruce wrote:
I can't believe the amount of money paid for Teins and you'd get better longetivity and I think ride-quality from the stock combo!
Actually I've got about 110,000kms out of my old HAs now and they still come out fine on the test bench. Never been rebuilt and I think the ride is pretty good, on 5/4, 7/5 and even 10/7 spring rates. I'd like to see how long all the Taiwanese ones last. :roll:
Re: Tein rattles
Postby Okibi » Mon Aug 25, 2014 9:18 pm
My flex must be over 10 years old now, thought i'd killed them a few weeks back but they're still going strong.
roket52
Re: Tein rattles
Postby roket52 » Tue Aug 26, 2014 6:47 pm
I believe my MCA Blues have the exact same issue. I ve been trying to find out what the heck the noise is for ages now. Glad I read this post
NB8B| MCA Blue 10K/7K |SE Sways| 8lb Flywheel| 4.1 LSD| Lots a Fun!
Re: Tein rattles
Postby 93_Clubman » Wed Aug 27, 2014 10:47 am
bruce wrote:Is $55 from fleabay a good price for a pair of Tein spanners?
Reckon I've seen them at a better price, but it might not have been for a pair. Also, generic brand ones of the right size will work & are cheaper.
Re: Tein rattles
Postby bruce » Wed Aug 27, 2014 11:08 am
Ta. I've ordered a pair and will fiddle with teins next week.
I reckon loosen them off and slide clear tubing over the ends of the springs, I guess both ends.
Charlie Brown
Re: Tein rattles
Postby Charlie Brown » Wed Aug 27, 2014 2:23 pm
bruce wrote:Ta. I've ordered a pair and will fiddle with teins next week.
I'm at a loss to understand why the fitting of rubber tubing to the spring would stop rattles.
If you have the correct length spring with the correct preload, the spring never leaves the spring seat on full droop.
Re: Tein rattles
Postby bruce » Wed Aug 27, 2014 2:34 pm
I believe there's a bit of wear involved, which allows the spring to move when unloaded. We're talking about a tiny amount of wear.
sailaholic
Re: Tein rattles
Postby sailaholic » Wed Aug 27, 2014 2:51 pm
But the preload should keep the spring firmly held against the seats unless your getting air rally car style.
Re: Tein rattles
Postby manga_blue » Wed Aug 27, 2014 3:06 pm
Earlier Teins don't have preload adjustment, only a fixed top perch with an adjustable bottom perch that has the weight of the car sitting on it. I use helper springs to stop them from coming free at full stretch.
Like this (obviously not my car):
ralt
Re: Tein rattles
Postby ralt » Wed Aug 27, 2014 4:59 pm
Hi.
You do not need "c" spanners. Just put a long screwdriver into one of the indentations and hit it with a hammer is the best way to undo and tighten and is a lot easier than those spanners.
project.r.racing
Re: Tein rattles
Postby project.r.racing » Wed Aug 27, 2014 5:53 pm
Never had this problem with bottom of the range Taiwanese made coilovers for past 10+ years.
I am also at a loss to the rattling of fully load encompassed springs.
Re: Tein rattles
Postby bruce » Wed Aug 27, 2014 7:23 pm
I'd rather use c spanners than mark up my twins.
Can someone point out what else needs tightening in the rear? Don't want to accidentally bugger the alignment.
taminga16
Re: Tein rattles
Postby taminga16 » Wed Aug 27, 2014 9:50 pm
bruce wrote:I'd rather use c spanners than mark up my twins.
Bruce,
A good rule of thumb is to tighten everything that you have undone under the weight of the vehicle.
Greg.
P.S. Write down every adjustment and use the same piece of road for testing, it is too easy to get lost in what you have done.
Greg.
ralt
Re: Tein rattles
Postby ralt » Wed Aug 27, 2014 11:25 pm
Hi.
Once you have locked the top lock ring to the ring under the spring try and turn the lock ring up with you spanner. If you can turn both your preload is not correct continue until it is very firm.Measure the spring length to ensure they are the same. Do both sides and measure from the top of the bottom lock ring to the underside of the top lock ring if the springs are the same in length and rate the measurement should be the same. Then you can set the vehicle height. Rattling is usually caused by not enough preload.
Re: Tein rattles
Postby bruce » Wed Aug 27, 2014 11:49 pm
Ralt, you might have nailed it. Let me digest your instructions....
Users browsing this forum: No registered users and 229 guests
