Rear Camber
Charlie Brown
Postby Charlie Brown » Tue Jan 02, 2007 11:22 am
kev.yan wrote:the camber will be even worse with the weight of the driver. As the lower to car the lower the camber.
I thought it would have been that way too but the alignment machine proved that it's the other way round when I got into the car.
A quick check of my sheets show 0.2 degrees more negative on the driver's side front and 0.3 more on the rear than the passenger's side.
deez
Postby deez » Tue Jan 02, 2007 1:58 pm
Mine's similar...it goes against logic doesn't it? You'd think with the driver in the car you would end up with even more negative on the driver's side :?
89 Eunos Roadster
Users browsing this forum: No registered users and 132 guests
