Deep Dish Rims that fit the NA
- Boags
rjr666 wrote:
A little wing on that would look very schmick! Not a fully dorifto adjustable downforce Gran Turismo style one, that would look sh!te.
Boags
- Vehicle: NA8 - Turbo
yea it works, i basically just disconnected the lines off the pump chucked that and its bracket to teh side and put a brass fitting between the two lines after i drained as much of the fluid (just by turning the wheel side to side, this pushes the fluid out) as i could.
Leaving everything else in there allow the rack to stay lubricated and allows no pressure to biuld up with fluid or air that is in there.
Feels great, and i run a +20 or +25 offset rims on the front all the time.
Dave
Dave
- RaYmO
- RaYmO
kula wrote:ok,
i finally did a test fit with my WORK wheels..
15x8, +35.
195/50/15 rubber and it fits, but the inner lips seem to rub.
ill do a guard roll and i reckon it will be fine
they fill the guards brilliantly..
as soon as they are in, ill post pics:)
After a bit more looking I found these:
Is 15x7 +4 offset going to be a bit too badass for the guards?
- godfather of saké
RaYmO wrote:Is 15x7 +4 offset going to be a bit too badass for the guards?
Phwoarrr....that might be pushing it a little. Even at 7in+20 you would need to roll the guards to get it all to fit, and these would stick out a further 15mm.
Here's an NA with 14x7in+3,
http://www.rs-watanabe.co.jp/images/use ... truth3.jpg
http://www.rs-watanabe.co.jp/images/use ... truth2.jpg
http://www.rs-watanabe.co.jp/images/use ... /truth.jpg
Looks great but the wheels are actually sticking out past the edges of the body so I'd be surprised if they didn't rub.
- Benny
If you do a \"proper\" flare which is folding out the inner lip and rolling the whole thing (you may possibly need to cut and weld the gaurd to make it all smooth, but i'm not sure as i havent got a gaurd roller) then you can fit in a 15 X 7 +0 easily. Well no easily but the wheel will sit just inside of the gaurd and you wont/shouldn't rub.
How do i know this?
Well i'll get a photo of my mangled gaurd up soon, but just for shits an giggles (and to tet if a 0 offset rim would fit) i put my 25mm spacers on the front of my car with my +25 rims. I found that yes the wheel would rub but only when turning and if you dont have rock hard suspension
But i flipped out the inner lip thingy and rolled it with just a bit of 2inch exhaust pipe off cut. The gaurd, if it was smooth, looks really nice and fits the wheels nicely ie they are filled.
My guard on the other hand is not smooth and looks terrible/mangled, but hey at least its only one of them and at least i know that my rim of choice will fit when i do get it eventually. Plus it suits the look of rest of my car
Dave
How do i know this?
Dave
Users browsing this forum: Google [Bot] and 147 guests
