Tyre pressures
Brad
Postby Brad » Sun May 07, 2006 11:57 pm
UPDATE: At the Natmeet I had a chance to play with presures. For the track I found 32 hot to be the best. On the road I run 32 cold.
Slugoid
Postby Slugoid » Mon May 08, 2006 1:58 am
I used 33 rear, and 34-35 front hot on track to be quite good. Any less than 32 hot I experienced a bit of oversteer and screeching, and didn't experience much if any understeer the whole day.
RobbieRat
Postby RobbieRat » Mon May 08, 2006 8:32 am
32-33psi all round cold on 205/45/16
Insurgence
Postby Insurgence » Wed Jun 07, 2006 4:21 pm
I just checked my pressues.
44 hot! damn those tyre fitters!
and cos they only refitted 3 tyres i had 3 x 4x psi and 1 x 30 psi !
i adjusted them so they are 40 hot, Can anyone tell me how much tyre pressures vary depending on hot/cold?
NB8A
QwikMX5
Postby QwikMX5 » Wed Jun 07, 2006 4:50 pm
After a bit of experimentation, I now run 34- 35psi cold on 205/40/17 at all corners. Good turn in and grip levels, whilst still comfortable at high speeds.
jules
Guitar Hero
Postby jules » Wed Jun 07, 2006 4:51 pm
Since we're revisiting this topic, as mentioned I run 33 front/34 rear.
I HATE understeer, and have assumed that with the slightly harder rear, it shoud make the car a bit more neutral leaning towards oversteer.
Suspension settings are the same all round.
Does this make sense to any of you propeller heads, or am I just having a toss thinking that I can feel 1psi, cause I can tell when the tyres are down by 2psi.
Jules
JBT
Postby JBT » Wed Jun 07, 2006 4:54 pm
Insurgence wrote:Can anyone tell me how much tyre pressures vary depending on hot/cold?
3-5 psi or more depending on what you're doing to them. BTW, I think 40 psi hot is far too high for the street.
Insurgence
Postby Insurgence » Wed Jun 07, 2006 5:11 pm
ok i'll do a bit of experimentation. i'm not sure what is normal and what's not.
but maybe i can't really tell because my car has done >100,000 and it's still on stock suspension (i think) :P
i did notice more road noise when i got the new fronts put on, not sure if that is the new tyres or the high pressures :mrgreen:
NB8A
JBT
Postby JBT » Wed Jun 07, 2006 7:06 pm
Try about 32 psi cold. That should be fine for street use IMHO.
JSE
Postby JSE » Thu Jun 08, 2006 2:33 pm
38psi F and R for my C-Drives
Insurgence
Postby Insurgence » Sat Jun 17, 2006 3:13 pm
JBT wrote:Try about 32 psi cold. That should be fine for street use IMHO.
Hey I finally got around to deflating my tyres.
whoa it feels so much better now! thanks :mrgreen:
NB8A
conchaae
Postby conchaae » Sun Jun 18, 2006 2:04 am
I run 36psi cold all round for the street and 38psi hot all round for the track.
For the street the psi doesn't come up all that much when hot and is a good balance between ride comfort & ride safety (No good having psi too low :arrow: weak tyre walls = slower response time from rim to rubber). But if I am having a spirited drive, the psi comes up to \"track psi\" for that familiar feel. I've spent a lot of time learning about this matter and have heard from the best. In the end it's all personal choice hence why it always comes up as a good discussion topic.
That's my two cents and here's where I brag...see sig for current all time lap record for a standard NB8 at Wakefield. :P :mrgreen:
Was just getting started, now in semi-retirement
Silver '01 NB8B Stock Standard Wakefield 117.83 ... 117.26 ... 116.95 ... 116.90
Users browsing this forum: No registered users and 149 guests
