Anyone lowered their MX-5 NC Limited Edition (LE) ?
ncmx5
Postby ncmx5 » Mon Apr 17, 2006 11:29 pm
okay, i dont like my king springs on stock suspension.
Its been 1000kms on them. The ride is hard and stiff and when you go over bumps and pots in the ground u judder.
Ive been on 2 black spur/reefton runs and the car doesnt seem to dampen well and when i take on corners i find it skidding around.
Im going to put back my stock springs, do the spur again and see what it's like. Might have to get some bilstein pss9 or tein SS adjustables!
dissin
Postby dissin » Sat Apr 22, 2006 8:05 pm
let us know the results - im sure when u go back to the stock standards it will feel fine without the bone jarring when hitting bumps
pastapete
Postby pastapete » Thu May 18, 2006 9:26 am
The Eibach springs finally arrived, after more than 2 months of waiting. Early impressions are very positive, less body roll to some extent, looks great, less nosedive under brakes. I do notice slightly heavier steering, so I might get a suspension shop to check out the alignment. The spring fitting and alignment was done by my local Mazda dealer same day as my 6 month service, I gave them the Mazdaspeed spring fitiing and alignment instructions, so it should be okay... Will be nice to verify, though
APD
Sway Bars
Postby APD » Mon Jun 12, 2006 7:23 pm
Have had whiteline make up front & rear adj sways for the NC LE through Fulcrum Brisbane got rid of the horrible roll when corning currently front adj minum setting rear in middle setting 1.25 neg camber will upload specs when i can find them currently understeer will play with pressures & sways. Looking at fitting Teins CoilOvers. Get rid of tyre guard air gap Will let U all Know.
Users browsing this forum: No registered users and 138 guests
