ksharp wrote:Bit the bullet and bought the Ohlins, eagerly awaiting shipment
you won't regret it!. What was the damage shipped to you?
sailaholic wrote:Why adjusting ride height via base height is bad in pictures
http://www.mcasuspension.com/infosheets/baseheight_pics.pdf
sailaholic wrote:I get what your saying. Travel runs out when something touches something else it shouldn't. Dump to ground, wheel to guard. Shock casing to bump stop.
Having said that. I can't see any snake oil in what they bare saying. Seems to make sense to me.
hks_kansei wrote:Basically the bump stops are there for a reason, to limit travel to prevent things like wheels bashing guards, or the sump smashing the ground.
greenMachine wrote:hks_kansei wrote:Basically the bump stops are there for a reason, to limit travel to prevent things like wheels bashing guards, or the sump smashing the ground.
Bump stops are part of the damping - you can tune your bump stops, if you plan on using them (as opposed to using them to stop the bottoming). I have just changed the bump stops in the rear of the race car for this reason.
