Grinding/knocking noise while cornering right
Re: Grinding/knocking noise while cornering right
Had a similar issue. Would happen mostly when turning right. I also suspected back left hub or a LCA bush. Turned out to be muffler hitting a bolt on the heat shield!
StanTheMan wrote:another member tried to do an internal engine clean. Got compression lock up. Bent all his rods.
What did he put in the engine to do that?
Just so I never do it
Actually it's worth reliving the whole UA water thread.
viewtopic.php?f=29&t=26318
Great guy, sadly missed here.
- Steampunk
So glad his memory is kept alive
Coincidentally "Max" turned up to our Mt Nebo run just last Friday after a too-long (more than 2 years) absence from current owner.
- StanTheMan
Boagsy won that award if I remember correctly. Is he still around?
