Are yellowspeed coilovers too low?
Ubik
Postby Ubik » Wed Oct 29, 2014 12:54 am
Hola Señors,
I am looking at buying an mx5. On inspection everything about it seemed ideal for me, except it was way too low. I reasoned that it was fitted with yellowspeed coilovers, which are adjustable for ride height, so I paid a small cash deposit thinking I could raise it up.
However, I am now worried that I don't actually know if it can be raised, for all I know it is presently in the top position. I have read that the highest position on yellowspeeds is a fair bit lower than stock. I can accept a little bit of a drop, but I want to be able to drive over speed humps and up driveways without much greater care than normal. As it is, when I opened the passenger door I worried about smashing it on a normal low gutter.
This is the car in question:
I am wondering if anyone with experience with yellowspeed coilovers is able to tell from these pictures whether the car can be raised? And if so, any estimate by how much?
Thanks very much
kazama
Re: Are yellowspeed coilovers too low?
Postby kazama » Wed Oct 29, 2014 8:58 am
It should be able to go higher than that. Worst case scenario you can sell them and buy others OR im sure you can get spacers
Postby Regie » Wed Oct 29, 2014 10:31 am
I had yellow speeds in my old nb. It sat a fair bit higher then that.
You should be able to raise it up a fair amount
emily_mx5
Postby emily_mx5 » Wed Oct 29, 2014 2:35 pm
Perfect ride height!
But yes they can most definitely go higher than that.
Just remember you'll need a new alignment whenever you change the ride height.
Postby Lokiel » Wed Oct 29, 2014 5:43 pm
emily_mx5 wrote:Perfect ride height!
For optimal handling, NA/NBs were intended to have the rear about 0.5" higher at the rear - this car looks to be higher in the front.
Just a warning about going too low - it gets old real quick when you're dragging your arse over even small speed bumps and you spend a lot of effort driving around car parks trying to avoid them. Here in Brisbane where it's very hilly, going too low makes your car almost undriveable.
Find a ride height that you're happy with, then get the alignment as emily_mx5 recommended.
Beelzeboss
Postby Beelzeboss » Wed Oct 29, 2014 6:41 pm
I had mine completely maxed out on the top end of the height adjustment, and 5mm more preload dialed in on the rear and it ended up with the frame rails about 120mm over the ground. I'd like them to go higher
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
project.r.racing
Postby project.r.racing » Wed Oct 29, 2014 9:51 pm
Beelzeboss wrote:I had mine completely maxed out on the top end of the height adjustment, and 5mm more preload dialed in on the rear and it ended up with the frame rails about 120mm over the ground. I'd like them to go higher
120mm is more than stock.
markwid
Postby markwid » Thu Oct 30, 2014 9:16 am
project.r.racing wrote:120mm is more than stock.
Hmnn, seems too low for stock ground clearance because my NB looked SUV-like to me before changing to coilovers.
Checked wiki and stock NB is 135mm, NA is 140mm.
Nevyn72
Postby Nevyn72 » Thu Oct 30, 2014 9:28 am
For the frame rails?
Just measured my NB SE on stock suspension and the (front) frame rails are @ 110mm and pinch welds are @135mm.....
Ubik
Postby Ubik » Thu Oct 30, 2014 9:42 am
Thank you for your replies, 15mm below stock sounds like I won't have any problems with ride height.
project.r.racing
Postby project.r.racing » Thu Oct 30, 2014 10:52 am
Cannot be. A BK Mazda 3 has 130mm clearence. Both NA and NB are lower.
project.r.racing
Postby project.r.racing » Thu Oct 30, 2014 10:54 am
Yeah that seems right. Other poster must be measuring from pinch welds.
Users browsing this forum: No registered users and 58 guests
