I need to raise my ride height by less than a cm (I'm like 97mm at lowest point)
I have a few options..
1) Somehow carve out like 100kg of car and let gravity (or lack thereof) do the trick
2) Block the springs by 1cm?
3) Put stock rear springs on the REAR only. This would have a little rake effect and hard front soft rears. I feel like this is probably stupid and would throw the balance right out though (currently have Mazdaspeed spring all round)
What would jesus do?
Raise height by 1cm
Raise height by 1cm
"Don't go crashing into Vulvas. *Volvos"
Re: Raise height by 1cm
50psi in to tyres
- Vehicle: Non MX-5
jesus would buy coilovers...
- fastfreddygassit
- Waitin' for a mate
Is this to get around a canary?
If so, then:
1.
2. Present with a fuel tank that is almost empty.
3. Take spare wheel, jack, etc out of boot.
4. Do a Wun911 and remove passenger seat.
or
5. Fitter another set of wheels with higher profile tyres or that have an increased overall diameter.
and if this is not for RWC purposes, then:
If so, then:
1.
TTT wrote:50psi in to tyres
or
project.r.racing wrote:jesus would buy coilovers...
- Vehicle: ND - Turbo
Is it just for a pit pass? I think your spring rates are 3.8f and 2.8r so if its just at the back you're too low remove 16.8kg of fuel and there's your 3mm. Tyres to 50psi as TTT says.
GHETTOCET
Is this the same bloke who got pinged before for a low car and wanted to argue the toss with the law about what surface it was measured on etc.- and the engine that did not run well without oil etc etc. Poor car - it has its ups and downs.
Users browsing this forum: Google [Bot] and 60 guests
