brake setup
MrsB
Re: brake setup
Postby MrsB » Sun Nov 24, 2013 3:21 pm
Okibi wrote:
chops wrote:i think they will, 4 and 6 piston are listed as fitting 15's...
Which 15s? one of my mates couldn't fit them under his 15s.
Been running them under 15 x 8 6ul's. there are 3 sizes available mine are 6 piston specifically for 15's
Chris
Re: brake setup
Postby Okibi » Sun Nov 24, 2013 3:49 pm
Thanks Chris.
chops
Re: brake setup
Postby chops » Mon Feb 03, 2014 8:21 pm
Well I bit the bullet and bought the 6 piston yellowspeeds and have to say I am quite impressed, felt much better than the Wilwoods at Wakefield yesterday. Did need to use 3mm spacers though
Appreciate the advice MrsB
Re: brake setup
Postby Magpie » Mon Feb 03, 2014 8:43 pm
What is the thickness of the discs for the yellow speed? The stock NB8B rotors (front) are 22mm and the Wilwood are 20.5mm.
chops
Re: brake setup
Postby chops » Mon Feb 03, 2014 9:02 pm
26mm
Re: brake setup
Postby Magpie » Mon Feb 03, 2014 9:32 pm
Nice that should make for good heat management. Also explains why stock rotors are better than Wilwood (ducks for cover).
Hellmun
Re: brake setup
Postby Hellmun » Mon Feb 03, 2014 10:27 pm
I'll add I ran the 11.75" kit from TSE yesterday. No rotor cracking, no pad deposits and barely any pad material used. It's still using 20.5mm diameter rotors like the old kit but the rotors are beefier (veins are smaller so more meat) and taller diameter. Time will tell how long the pad/rotor lasts but so far.... effective and cheap.
Users browsing this forum: No registered users and 224 guests
