I recently went to by new pads for my NB8B brakes on my NA6.
I have been advised that Hawk distinguish between 01-02 sport brakes rears and 03-05.
Does anyone know if there is a difference between the 01-02 and 03-05 rear callipers or is it just the pads?
How different are the pads? Are Hawk the only pad maker that distinguish a difference?
Has anyone come across this before??
Thanks.
NB8B Rear pads - Is there a difference?
- Vehicle: Non MX-5
Re: NB8B Rear pads - Is there a difference?
a few threads down. it's a usdm thing that is confusing you. there is a post explaining it in this thread.
viewtopic.php?f=30&t=55649
Is the post that explains it mine?
That was in relation to rotors, not pads.
Direct from Brian at Good-win "Hawk makes a distinction between 2001-2002 Rear SPORT…..and 2003-2005 Rear Sport pads. SPORT Rotors same size either way."
MiataTurbo guys seem to think that the backing plates are different, but pads are possibly interchangeable.
Its also possible that the difference related to the fact mazda have a differnt part number for SE brakes, although general consensus is they are identical to standard NB8B apart from colour. but then why is it different 03-05 and not 04-05?
- 29OCC
Do products have different part numbers for colours?
I baught a front and rear set of Bendix pads.
DB1386 GCT -Front
DB1508 GCT - Rear
Haven't fitted them yet however.
You were saying the American 'Sport' model brakes went standard in 03? Was there a change then?
DB1386 GCT -Front
DB1508 GCT - Rear
The disc size stayed the same, the question is wether or not there was a change to the calliper and/or pad. It seems unlikely, but why are there 2 part numbers for the Hawk pads?
- 29OCC
Exactly what I mean, there are always little changes when production moves full scale.
Hawk still supplies to an American market?
More digging has confirmed that the rear NB8B callipers are all the same other than the SE version is painted silver.
Hawk is the only company that seems to have 2 part numbers. Other brands use just one part number for the rear pads.
Brian seems to think the only difference between the 2 hawk versions is a small tab on the rear pads.
- Boyracer
- MX-5 Encyclopedia
In USA they had 2 versions of the NB8B the Sport version is the same as the Aussie NB8B.
The non sport version NB8B which was not available in Australia has the smaller NB8A brakes and 5 speed gearbox.
So when you order anything for a NB8B you have to say Sport version.
Users browsing this forum: No registered users and 17 guests
