Does anyone know what the actual 'delivered height' of the 1992 NA6 was ?
Apart from to high
Every suspension dimension I could ever not need is in the manual--except that one.
Actual 'Delivered height: NA6 ?
Re: Actual 'Delivered height: NA6 ?
According to Mazda front can be anywhere from 328 to 377mm and rear from 346 to 395mm, so long as you meet their side to side and front to rear difference criteria.
Gives you plenty to work with, doesn't it?
I've heard that 340-350mm front was pretty common.
Thanks for that , jeez i thought these were aftermarket adjusted heights not possible delivery hieghts FMOB.
I'm running 365 R / 355 F on oem
Users browsing this forum: Bing [Bot] and 235 guests
