PlastiDip your wheels...?
Silvia
Postby Silvia » Sat Apr 07, 2012 2:36 pm
Has anyone here done their wheels with this plastic spray-on coating? It looks pretty good on UTube (Google it) and if I can find somewhere in Brisbane I'm tempted to give it a go. I don't imagine Aust.Post likes it posted interstate..... It's about $9 can in U.S. but seems to be $40 here....
Silver Nomad
2002 NB8C
Re: PlastiDip your wheels...?
Postby hks_kansei » Sat Apr 07, 2012 6:01 pm
I've read that the plastidip doesn't like brake dust (it eats into it apparently) So if you used it you'd need to clean the wheels often.
If you know what colour you want, why not use paint?
It's cheaper, it's stronger, it will last longer.
Smokinscotty
Postby Smokinscotty » Sat Apr 07, 2012 7:07 pm
+1 for painting.
Not wanting to sound rude, although I'm curious,
What benefits were you hoping to get from this?
So lets go!
Silvia
Postby Silvia » Sat Apr 07, 2012 7:25 pm
Just checkin' it out. Certainly needs less prep work, no sanding or undercoats etc. and seems an easy way to get the job done. Have you seen the tool handles it's commonly used on? Very tough.
Silver Nomad
2002 NB8C
Postby hks_kansei » Sat Apr 07, 2012 9:47 pm
But tool handles aren't left outside in the elements normally.
Or subjected to acidic brake dust
or road salts etc
or the great changes in temperature wheels deal with.
Also, Plastidip is deisgned to peel off after a while.
If you don't do any prep work on paint it will also peel off.
bootz
Postby bootz » Sat Apr 07, 2012 10:52 pm
hks_kansei wrote:But tool handles aren't left outside in the elements normally.
or road salts etc
Road salts in Australia. :?: :?:
Hjt
Postby Hjt » Sat Apr 07, 2012 11:52 pm
Speaking from experience, I have coloured my side skirts, front bar, badges and canards in the flat black.
It will chip, although it can be easily touched up with-out blemishes in the tone, it is water resistant, once wet the water easily dissipates.
Brake dust will stick to hit, and if you do paint it make sure you paint plenty of coats to make it thick and easy to peel off later.
PS Please use a proper breathing apparatus when applying as the chemicals are highly toxic.
Postby hks_kansei » Sun Apr 08, 2012 7:42 am
bootz wrote:Road salts in Australia. :?: :?:
Minerals, sand, chemicals, all the sh*t that builds up on the road surface.
Not exactly salt per-say.
Postby Jeo » Mon Apr 09, 2012 2:37 pm
Yes.
Ok, not quite. I bought them like this but it is PlastiDip.
Users browsing this forum: Bing [Bot], Google [Bot] and 246 guests
