Lateral Locks for Swaybars
NC2005
Postby NC2005 » Fri Nov 04, 2011 8:24 pm
Have Whiteline sways fitted to NC.
Front are 2 way adjustable and Rear are 3 way adjustable.
How are they adjusted? Do I need to unbolt top and bottom of the End Links? I tried just unbolting top end but nothing moves .
Is it thought neccesary to fit Lateral Locks, the Front had them but they failed within a few months and the Rear did not have them. I can get better Alloy ones from Whiteline.
Charlie Brown
Re: Lateral Locks for Swaybars
Postby Charlie Brown » Sat Nov 05, 2011 12:07 am
You just move the link on the sway bar.
Set the front to soft. Furthest out. Set the rear bar to the middle setting and then try it out on a round about. If it oversteers move the rear bar position out to full soft. You will never need to set the front bar to full hard.
My bars never had a lock to stop the bar sliding across the bushes and I never had a problem with them.
