NC - Sway Bars
slowpoke
Vehicle: 10AE
NC - Sway Bars
Postby slowpoke » Wed Sep 15, 2010 10:31 am
Can someone please inform me of what the sizes are of the original (factory fitted) sway bars that are fitted to an NC? With thanks from slowpoke
taminga16
Re: NC - Sway Bars
Postby taminga16 » Wed Sep 15, 2010 10:40 am
NC2 Sway Bars. Front. 23.5mm.
Rear. 11.5mm.
Greg.
Charlie Brown
Re: NC - Sway Bars
Postby Charlie Brown » Wed Sep 15, 2010 10:46 am
taminga16 wrote:NC2 Sway Bars. Front. 23.5mm.
Rear. 11.5mm.
Greg.
Hmmm, there's a spec. change.
NC1 Sway Bars
Standard
Front.......21.0mm
Rear........12.0mm
Whiteline
Front........24.5mm
Rear.........15.0mm
slowpoke
Vehicle: 10AE
Re: NC - Sway Bars
Postby slowpoke » Wed Sep 15, 2010 11:01 am
Thanks for this useful info fellers!
slowpoke
Vehicle: 10AE
Re: NC - Sway Bars
Postby slowpoke » Wed Sep 15, 2010 11:24 am
And what of the RX8's bars? I understand that they can be a good swap-over..? Any measurements known of these, please?
Charlie Brown
Re: NC - Sway Bars
Postby Charlie Brown » Wed Sep 15, 2010 1:38 pm
Come on slowpoke, don't make us do all the work for you. Use the search function. :roll:
And sure the RX-8 bars are a cheap swap but they aren't adjustable so you'll end up with understeer.
slowpoke
Vehicle: 10AE
Re: NC - Sway Bars
Postby slowpoke » Wed Sep 15, 2010 2:32 pm
I tried the SEARCH FUNCTION apropos measurements of the RX8' bars but no suitable matches could be found... But thank you for your reply.
Charlie Brown
Re: NC - Sway Bars
Postby Charlie Brown » Wed Sep 15, 2010 3:17 pm
slowpoke
Vehicle: 10AE
Re: NC - Sway Bars
Postby slowpoke » Wed Sep 15, 2010 7:38 pm
Thank you Charlie Brown!
John
Re: NC - Sway Bars
Postby orx626 » Thu Sep 16, 2010 12:01 am
With changes to other parts of my NC I've found the RX-8 sway bars (manual front & rear) to work extremely well on both the street and track.
