koni shocks and springs need HELP !!! **********
JDM-MX5
Postby JDM-MX5 » Tue Apr 06, 2010 9:28 pm
hey guys , need help with my spring and shock combo
are the longer struts surpose to be for the fronts ? and the shorter struts for the back ?
right now i have kings springs with the combo , and the koni shocks are in the top perch ? is that the lowest setting or the bottom perch is the lower setting to lower the shocks more ?
do u guys get me ?! LOL
any help will be appreciated !
cheers
JDM-MX5
Postby JDM-MX5 » Tue Apr 06, 2010 9:49 pm
anyone wanna help me adjust it to the lowest setting ??!?
Wivvix
Postby Wivvix » Tue Apr 06, 2010 9:59 pm
The longer shock bodies are for the front. The shorter shock bodies are for the rear.
The higher the perch, the higher the ride will be. NA or NB?
Si.G
Postby Si.G » Tue Apr 06, 2010 11:59 pm
If you have an NA, I would not recommend the lowest perch on the rear, unless you have top mounts that give you extra suspension travel (not sure if it a problem on the NB). On my NA, my Koni/King springs were originally set up on the standard top mounts on the lowest perch and my car had no suspension travel - it was on the bump stops, so it was very bouncy and potentially dangerous when driving on bumpy roads.
if you are wondering what I mean by different top mounts - http://www.flyinmiata.com/index.php?deptid=4537&parentid=0&stocknumber=13-57100%20%2010MM
there should be plenty of threads on here about the suspension travel problem on the rear. You can see my top mounts here - http://mx5cartalk.com/forum/viewtopic.php?f=57&t=40374
Si.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
Locutus
Re: koni shocks and springs need HELP !!! **********
Postby Locutus » Wed Apr 07, 2010 1:45 am
^agree
I went from middle to top perch on mine and the improvement in ride quality was astounding. I would not recommend anything lower than top perch for the rear unless you have shortened bump stops and/or upgraded rear top mounts.
JDM-MX5
Postby JDM-MX5 » Wed Apr 07, 2010 2:47 am
thanks for the help guys , REAR shocks will be left on top perch as it is ..
but can sumone help me or someone can do it cheap to lower my front PERCH to the lowest setting ? im around Liverpool NSw
CHEERS GUYS !
Juffa
Postby Juffa » Wed Apr 07, 2010 11:49 am
JDM-MX5 wrote:but can sumone help me or someone can do it cheap to lower my front PERCH to the lowest setting ? im around Liverpool NSw
CHEERS GUYS !
Basically there are two ways to do this.
1. Completely remove springs and shock aborbers as a single package from the car. Use a spring compressor to remove the springs. You can then move the 'C' clip that supports the perch. Compress the springs, re-fit them to shock absorber and reinstall the completed package. Note the use of a spring compressor by an novice is not recommended, seek help of an experienced person or a professional.
2. Follow the link below and use the instructions for removing the shocks without using a compressor. As you only want to adjust the perch height you can leave the shock absorber attached to the bottom mount and still remove the spring to gain access to the 'C' clip and move it. I used this method two weeks ago to move the front and rear perches.
Miata.net garage ==>> http://www.miata.net/garage/garagehandling.html
J.
JDM-MX5
Postby JDM-MX5 » Thu Apr 08, 2010 12:32 pm
thanks for info , but im still not really sure how to do it ..
anyone around sydney wanna help me do it ?!?! cheers
Users browsing this forum: No registered users and 302 guests
