15x7 with offset -12
cosmo
Postby cosmo » Fri Nov 06, 2009 11:47 am
Would these fit an NA...? (tires 205/50/15)
2007 Megane F1 R26. 1992 NA6. 1993 205 GTI series 3.
RG.net
Postby RG.net » Fri Nov 06, 2009 11:50 am
Not with those Tyres.
Even with stretched tyres you would have too much poke and need to be slammed for the wheels to look any good on the car.
broady
Postby broady » Fri Nov 06, 2009 11:54 am
You'd probably want flares.
人馬一体 NA8
6/5/2010
cosmo
Postby cosmo » Fri Nov 06, 2009 11:59 am
ok... the add says they fit RX2, RX3 & RX7 (thought the MX5 would be close...
Postby Jeo » Fri Nov 06, 2009 12:14 pm
RX2 and 3 aren't 4x100 either
green_comet
Car Detailing Guru
Postby green_comet » Fri Nov 06, 2009 1:04 pm
That size wheel would sit the same as 15x8 0et wheel. You can pull it off but you need to roll/pull guards, slam your car, and run a fair amount of camber. Those tyres would have to go for some 195/50's or thinner.
Postby hks_kansei » Fri Nov 06, 2009 1:32 pm
cosmo wrote:ok... the add says they fit RX2, RX3 & RX7 (thought the MX5 would be close...
RX2/3 PCD = 4X110
RX7 Series 1 PCD = 4x110 (possibly series 2 as well)
NA/NB MX5 PCD = 4x100
cosmo
Postby cosmo » Fri Nov 06, 2009 1:46 pm
Thanks guys.....didn't want to slam car in any way, so might pass on them...
Postby hks_kansei » Fri Nov 06, 2009 3:15 pm
cosmo wrote:Thanks guys.....didn't want to slam car in any way, so might pass on them...
wont fit anyway, the wheel studs on the early RX series (RX2/3) are 10mm further apart than on an MX5.
