Wheel locking clunk
JBT
Wheel locking clunk
Postby JBT » Wed May 20, 2009 7:50 pm
The MX-5 is not FWD and does not have front CV joints. Maybe your steering rack is loose/broken or you have a ball joint loose/broken or some other serious issue with the steering.
NMX516
Wheel locking clunk
Postby NMX516 » Wed May 20, 2009 8:30 pm
The wheels might not be rubbing against the body work, but could be touching either suspension components or "chassis rail" if larger than standard wheels are fitted.
Garry
Wheel locking clunk
Postby Garry » Wed May 20, 2009 9:41 pm
My car used to make a horrible squeak on full lock. It turned out that the stone shield around the brake rotor had bent somehow and was rubbing on the lower control arm on full lock.
Charlie Brown
Wheel locking clunk
Postby Charlie Brown » Thu May 21, 2009 9:36 am
I can answer this one easily.
Wheel Bearing.
Hellmun had the same problem a couple of weeks ago at Wakefield.
Luckily Russell was there with a spare to whip off the old one and put on the newie.
