Aftermarket Wheel Bearings - A word of warning
CT
Postby CT » Thu Jan 29, 2009 3:58 pm
I've been buying Bearing Trader hubs for a couple of years now and just last week, grabbed a couple more. The bearings and hubs are made by NTN in Japan and sold locally through Bearing Traders. The latest couple don't actually fit. The ABS rings are 2mm larger in diameter than both Mazda ones and previous NTN ones. If you have purchased aftermarket ones and not fitted them, check them. The ABS ring diameter should be around 82.7mm - these were 84.7mm. Meanwhile, it's back to Mazda for spares.
Caffeine
Postby Caffeine » Thu Jan 29, 2009 4:49 pm
CT wrote:I've been buying Bearing Trader hubs for a couple of years now and just last week, grabbed a couple more. The bearings and hubs are made by NTN in Japan and sold locally through Bearing Traders. The latest couple don't actually fit. The ABS rings are 2mm larger in diameter than both Mazda ones and previous NTN ones. If you have purchased aftermarket ones and not fitted them, check them. The ABS ring diameter should be around 82.7mm - these were 84.7mm. Meanwhile, it's back to Mazda for spares.
Tried CBC?
CT
Postby CT » Thu Jan 29, 2009 11:30 pm
I am going to speak with them tomorrow but I am fairly confident that NTN are the only maker of aftermarket front hub/bearing assemblies for the NA/NB MX5s. I wouldn't be suprised if they supply Mazda as well - so I will be interested to see what I find. Will keep you posted.
Caffeine
Postby Caffeine » Fri Jan 30, 2009 8:16 am
I'll check downstairs, I still have the boxes that the CBC bearings came in and I'll find the part number...
mx5racing
Postby mx5racing » Fri Jan 30, 2009 10:27 am
Hey CT, we got a heap of sets from Powermax a couple of years back. They were identical to the CBC ones - you just had to swap the ABS ring over. Part number was KWB8013. Still got one left if you need it.
CT
Postby CT » Fri Jan 30, 2009 1:02 pm
Thanks Chris and Liam. It was just spare stock for me so I'm OK at the mo. If the CBC boxes are blue and the kit is a 130 something, they are NTN kits. These ones come with the ABS ring too. Will get to CBC next week and check....
CT
Postby CT » Wed Feb 04, 2009 9:24 am
I checked with CBC yesterday and their bearing kits are supplied by NTN too - all their stock is the same too - wrong size ABS ring......at leastthe guy at NTN knew of me and the issue....let's hope they can resolve it.
rascal
Postby rascal » Tue Apr 28, 2009 3:12 pm
Just on this, I need (I think) new bearings on the front of my 99 NB (non abs)
I rang Mazda and they quoted $250 per side, as cannot buy bearings seperately and have to buy the hub assy as well.
Is this correct? Is there another (cheaper) option?
How much are you guys paying for the bearing kits mentioned here?
Tks
Rus
Caffeine
Postby Caffeine » Tue Apr 28, 2009 5:50 pm
rascal wrote:as cannot buy bearings seperately and have to buy the hub assy as well.
Tks
Rus
That's correct, the whole hub assembly comes as a sealed unit. I paid around $130ish each for my ABS ring equipped ones.
philz
Wheel guru
Postby philz » Tue Apr 28, 2009 6:05 pm
CBC Caffeine?
CT
Postby CT » Wed Apr 29, 2009 9:17 pm
CBC or Bearing Traders.
Benny
Postby Benny » Tue May 05, 2009 6:10 pm
I had my front wheel bearings replaced recently by Heasmans as one of them was squeeking and sounding a bit dry.
He rang me to say the OEM bearings would cost me around $500, but he had some very good aftermarket ones for around $280 a pair.
Obviously, I went for the aftermarket ones.
Heasmans didn't say anything about the ABS ring not fitting etc., and they seem to be as good as gold to me.
