standard na springs
grump
standard na springs
Postby grump » Fri Oct 10, 2008 5:38 am
o.k. I know i can search for this but it becomes a time consuming, frustrating task. what is the spring compression rate for standard na springs, in kilos or lbs. also have found a place that will rebuild standard bilsten shocks at $120 a corner. I want to educate myself before i rush into replacing my suspension, so be prepared for some really stupid questions
Steampunk
standard na springs
Postby Steampunk » Fri Oct 10, 2008 9:12 am
No idea about spring rates, but send tbro a PM about rebuilding. From memory, I think he found a place that will do it MUCH cheaper and much more competently.
standard na springs
Postby manga_blue » Fri Oct 10, 2008 9:20 am
The MX5 suspension bible is in the Chassis Setup/Suspension Spreadsheet down the left column of http://www.fatcatmotorsports.com/.
Users browsing this forum: No registered users and 106 guests
