sportmax wheels - anyone used them
- 16bit
these are only going to be a street wheel so they will not get that much of a workout. stay tuned for when they come in.
who did you end up going through 16bit? JDM will be dropping their prices soon, so i have been told.
Adam_NAclubman wrote:
Thats an 8 +12 with pulled guards, 8 +0 Sportmaxx would sit even further out
8.5 +6 (sits the same distance out as an 8 +0) with reasonably stock guard, but it was still sitting on the jack, so I guess they'd tuck in a bit more but you still need to pump the guard a heap to get them in neatly I think
ADAM! what a tease!!! show us some shots of those jems!
what tyres you running, is there any scrubbing etc and how much lower is your can from stock
They're not Sportmaxx's, just wanted to show a similar offset since people were wondering how they'd fit
My car is looow. Not as low as it could go, but I wouldnt want to drive it any lower on the street
- 16bit
I should have my new combo in about a month - you will just have to wait and see.
just want to add that those pics are with no camber as the car is up in the air, they'll tuck in quite a bit when the car is back on all 4's
at least that's what it looks like, if you can correct me please do
Adam_NAclubman wrote:They're not Sportmaxx's, just wanted to show a similar offset since people were wondering how they'd fit
Fitment looks good.
Whats your centre to fender distance?
No idea, I had it fairly even all round before I started rolling the guards but now I need to set them all again as I had to extend the coilovers to get the guard roller in, then when I brought them back down I dont think I got them even again
http://cgi.ebay.com.au/SPORTMAX-002-513 ... dZViewItem
I got the 9.5kg weight from this ad. Maybe its a slightly different style sportmax, hence, extra weight.
- 16bit
spokes are quite a bit thicker so probably correct.
- 16bit
what size tire are you using?
195/45/15 front, 195/50/15 rear
- 16bit
sh*t me they tyre stretch a bit. would that compromise handling?
streching the tyre makes the sidewall stiffer, so it should make handling better
+ 1
But you need a bit of flex to grip, good on the back if you slide.
Users browsing this forum: No registered users and 284 guests
