NB struts into NA. Anything tricky?
Steampunk
Postby Steampunk » Mon May 12, 2008 8:43 pm
I will be installing Konis & Eibach from an NB into my NA. Is there anything tricky about it?
Will the brake lines foul anything?
They came with the NB strut tops/hats so no spring compressors needed.
Straight forward yeah?
Fatty
Postby Fatty » Mon May 12, 2008 8:45 pm
i know fat cat motorsports sell top hats that let you fit nb suspension to an na. dunno if the stock nb ones just bolt on or not.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Tue May 13, 2008 1:21 pm
The NB suspension bolts straight in...the only thing is they have a longer bolt at the top so they can be a bit tight to fit...I usually loosen the front lower arms at the inner mounts so they drop right out of the way.
just make sure you mark the adjusters before you loosen them so they go back in the same spot.
Steampunk
Postby Steampunk » Tue May 13, 2008 1:47 pm
Thanks James and Lou :)
Spranga
Postby Spranga » Tue May 13, 2008 6:38 pm
I thought you had to change the rear spring/perch mounts to make the shock shorter? If you don't the bum will sit up in the air :shock:
Steampunk
Postby Steampunk » Wed May 14, 2008 6:56 am
Spranga wrote:I thought you had to change the rear spring/perch mounts to make the shock shorter? If you don't the bum will sit up in the air :shock:
That is pretty much all that I was worried about.
Apparently you can get the Koni's re-threaded/re-collared so the perch sits lower.
I am crossing my fingers the Eibachssesses springs are lowered ones so at least I will have normal ride height if it does push the ass up.
OMY005
Postby OMY005 » Wed May 14, 2008 9:15 am
1red5 wrote:Apparently you can get the Koni's re-threaded/re-collared so the perch sits lower.
Check with Uncle Arthur, I'm pretty sure that is what he had done to his buy Fulcrum. Makes the ride height adjustable with a threaded collar. Looked very good.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Steampunk
Postby Steampunk » Wed May 14, 2008 10:30 am
Coolness. I'll be seein him at the dodgy day.
Thanks Andrew!
Steampunk
Postby Steampunk » Tue Jun 03, 2008 1:30 pm
NB struts are in. No drama at all.
Someone sent me a PM to tell them how the install went but I forgot who it was. :frown:
xhonda_boy
Postby xhonda_boy » Tue Jun 03, 2008 7:47 pm
Congrats!!!
It was me that sent you a PM.
Send us pics of the rear setup.. if you dont mind..
CHeers.
John.
Steampunk
Postby Steampunk » Tue Jun 03, 2008 9:21 pm
I took pics, but they are nothing special. I'll post them tomorrow from work as I only have 56k dial up at home.
John, so have you done yours yet?
If not then here are the big tips I got that were pretty much necessary in order to get it done right.
Front suspension:
- undo the big, long bolt that attaches the top wishbone to the chassis
- this will allow the top wishbone to drop down so you can angle the strut in
- undo the sway bar end-link so the front suspension can drop down even further
- you need to get someone to put a bit of weight onto the front suspension to bring it down a few centimetres whilst you fit the strut
Rear suspension:
- undo the bolt on the upper wishbone that connects it to the to top of the wheel hub
- undo the sway bar end link to, once again, allow the suspension to drop down further
- get someone who weighs at least 85kg to stand on the rear hub, thus pushing the suspension down, whilst you position the rear strut into place
It'll make more sense once you start to do it :)
Good luck
Andrew
Users browsing this forum: Google [Bot] and 212 guests
