will these fit an NB8A? PICS
marky210
Postby marky210 » Thu May 15, 2008 10:37 pm
Hi guys :D
I have come accross some wheels and just wanted to see what peoples view is on the size and how or if they will fit my NB8A :?: :P
They are: 17x8 +19 offset and 17x8 +14 offset centre hole on the rims are 57mm.
Mark :P
99 mx5, Brilliant Black with hardtop, cusco f/brace,intake and AVO turbo kit awaiting install.Tien SS coilover kit,BD Rollbar,16x7 Work Meister's!!
Postby orx626 » Thu May 15, 2008 10:49 pm
In two words Mark...no chance! Offset is the biggest issue! 15x7 +33 offset barely fit with 205/50R15 rubber.
Sorry,
Sheck
Postby Sheck » Thu May 15, 2008 10:50 pm
be prepared to do some fender rolling with a high possiblility of scrubbing at full lock, but it can be done, dont know about the center hole though.
make the car fit the wheels, not the other way around!!
post some pics!
Hellmun
Postby Hellmun » Thu May 15, 2008 10:50 pm
59.1mm on an mx5.
http://www.949racing.com/index.asp?Page ... D&ProdID=9[/url]
In regards to offset and rim width though, I hope your have your guards rolled and some camber at a minimum. I'm always running 2 degrees + camber, have stiff Tein Monoflex and have rolled guards and I can get rubbing on 215/40/17 road tyres when braking hard going down steep hills. Those wheels are +35 offset 7.5\" wide. Yours are slightly wider and offset further out....
For reference I actually had to roll my guards because of 205/50/15 semi-slicks getting gouge marks. Those wheels are +35 offset as well, the semi's are just 224mm wide I think.
I'm sure you can do it but I'd say you'll have compromises to make you don't particularly want in a street car.
marky210
Postby marky210 » Fri May 16, 2008 12:17 am
Thanks for the replys guys :D
I pretty much knew that they would be a verry tight fit and that scrubbing would be a big issue :frown: Im not the best workin out offsets and if they will fit but these are the puppies im in lurve with!!! One of the Sexiest wheels i my books-WORK MEISTER S1 8) JDM Goodness :mrgreen:
Ive got Tien SS and my ride is pretty stiff and from what i can see these will need alot of work to fit but it can be done you think......
Image[/url]
Cheers,Mark :D
Jimmy
Postby Jimmy » Fri May 16, 2008 12:58 am
the centre holes (wheel hub) on the mx5 (na, nb) are 54mm.
AB7
Postby AB7 » Sat May 17, 2008 1:47 pm
orx626 wrote: 15x7 +33 offset barely fit with 205/50R15 rubber.
I have 16 X 7 +25 offset with 205...and no probs at all. I didn't roll the fender either.
8 inch wide max is around +30's
marky210
Postby marky210 » Sat May 17, 2008 2:45 pm
Thanks for all the input guys :D
Ive always wanted to have a setup exactly like this:
http://img291.imageshack.us/img291/6565/dd17090pu8.jpg
with these style wheels-Work meister s1 and plenty of dish :evil:
I just want to know how do the get them in there and exactly what offset and width will get me whats in the above
Im not the best when it comes to offsets :frown:
Thanks again for your help guys :D
Mark 8)[/url]
stevesports
Postby stevesports » Sat May 17, 2008 4:18 pm
looks like a car from clubroadster. Possibly ask the people there to find out how to fit those wheels.
AB7
Postby AB7 » Sun May 18, 2008 1:01 am
Yep, that black NB is from Clubroadster, I did asked him before...its 16 X 8 Offset+ 9...yes 9!!!
Plenty of work... rolling, camber and fender pulling to make that fit.
PUR157
Postby PUR157 » Sun May 18, 2008 1:45 pm
Gimme a bucket for the drool will ya?
Good luck with it though...!
Postpicswhenyousucceedorban
:mrgreen:
Oneness of Man and Machine
