Can you have em just for the fronts? Or must I put them on all four wheels to gain the full benifits?
I want to take the car to nat meet so who makes them ADR aproved?
Does it prevent fade at all being metal does it disipate heat better?
Or is it purely just a better feeling issue?
Braided brake lines???
every ounce counts
- Matty
The braid is really just protection for a teflon line, which is the real benefit (stiffness etc). Won't do anything for fade, it's all about feel and modulation.
Doing just the fronts would give some benefit (probably more than 50% due to the pressure proportioning), but doing all 4 would be the best. Most are sold in 4-wheel kits anyway.
http://www.mx5mania.com.au/brakes.htm
http://www.braidedhoses.com.au/index.html
http://www.maltech.com.au/home.html do custom ones
I had Goodridge lines on my car.
Re: Braided brake lines???
[quote="wun911"]Can you have em just for the fronts? Or must I put them on all four wheels to gain the full benifits?
If you can't find them anywhere else I believe Adelaide Brake and Clutch does
- CT
- Matty
1red5 wrote:Regardless of brand or where you buyt it from , are they ADR compliant at all?
They can be. They just need to meet certain requirements, like the aforementioned rubber strain reliefs, and a manufacturer's label permanently affixed.
Details here
Users browsing this forum: No registered users and 101 guests
