Folks,
I gather the bearings in rear uprights are peened over, and considered non-servicable by Mazda (NA, NB at least).
All the same, has anyone ever replaced the bearing(s) in there?
Thanks - Gavin.
Are rear upright bearings replaceable?
- Boyracer
- MX-5 Encyclopedia
- adamjp
I have done one rear wheel bearing - as indicated a bitch of a job.
You might get the old one out if you know what you are doing, but MUST use a press to get the new one in. I stuffed around with it for an hour before giving in and taking it to my local machinist. He did it in 2 minutes with a hydraulic press.
You will also need a really big breaker bar and torque wrench. That nut is tight!
Adam
- irwin83r
adamjp wrote:I have done one rear wheel bearing - as indicated a bitch of a job.
cracks me up how the mx5s wheel nuts are tight as when most other cars are rather low a setting it appears.. or have i been talking to too many old car fans
Users browsing this forum: No registered users and 208 guests
