Rear bump stop modification
the roadster
Postby the roadster » Wed Jan 24, 2007 9:50 pm
Lower mine 40mm 20% stiffer K-mac spring and I'm happy with the set-up exept for K-mac apprentice fitter,should have buy a suitable spring compressor and do the job myself .Anyway bottom out at the back end from RTA's speed limiter road holes is not what I'm after, on the net there are many supplier of after maket pump stop with promise of smooth ride ...blar ..blar ..blar ..but I was just thinking what is wrong with cutting down the factory one ? the question is how much isn't ? or cut down will loss too much of its shock absorber ability.
Any advice from anyone with experienced in this is greatly appreciated.
Babalouie
godfather of saké
Postby Babalouie » Wed Jan 24, 2007 10:22 pm
Ta da!!
http://www.virkki.com/jyri/miata/bumps.html
I chopped the lowest 13mm of my 1.8 bumpstops
mr_rotary
Postby mr_rotary » Fri Jan 26, 2007 11:19 am
To me it's like cutting a spring - dodgy.
Do it right and buy something that's had brilliant reviews from the big forum with proven results:
http://www.fatcatmotorsports.com/FCMstops.htm
the roadster
Postby the roadster » Thu Feb 01, 2007 9:25 pm
I'd a chop off the bottom ring off ,since it's look like this is just to spread the load wider on the shock and to join up with the shock boot , the middle ring is doing the absorb of bump.
Result ? oh yes , no more bouncing on pothole and speedhump.
The K-mac springs combine with Bilsteins the chop rear bumpstop is a near perfect setup 8)
Users browsing this forum: No registered users and 151 guests
