Alignment update
suzi
Alignment update
Postby suzi » Fri Nov 17, 2006 8:14 pm
Getting new tyres tomorrow and just remembered I should get an alignment too....searched thru old threads & found quite a few about alignments but this has confused me even more (which isn't hard) because they all seem different!
Should I just leave it to the guys at Bridgestone who are putting the tyres on and assume they know what they are doing?
Thanks
Kim
Sunlight Silver 2002NB (Suzi)
SuperMazdaKart
Postby SuperMazdaKart » Fri Nov 17, 2006 9:06 pm
well you could & they'll adjust it to the book according to mazda factory specifications. there are some other settings for more aggressive driving if you want to go that way.
SPy vs. SPy
Re: Alignment update
Postby SPy vs. SPy » Sat Nov 18, 2006 1:26 am
suzi wrote:Bridgestone
your getting what.................................
please tell me your not wasting money on Turanzas............................
Told you where to go and what to buy...............
may a thousand visions of the lions road run flash before your eyes......
<insert emoticon for head hanging in shame>
suzi
Postby suzi » Sat Nov 18, 2006 8:01 am
Dont panic oh wise one!!!! I listened - you did tell me where to go & what to say & which tyres to get. and I did listen oh fountain of knowledge...... am getting PP s'2 BUT the place you said to go to,including the name dropping, was $255 per cnr and wouldnt budge from that (and teh guy was a knob & tried talking me into every other tyre under the sun) - I'm getting the PP 2's for $220 ea from the mob down the road.
Insurgence
Postby Insurgence » Sat Nov 18, 2006 11:16 am
Slugoid where is a good place in melb to get your alignment done?
/thread hijack
NB8A
SPy vs. SPy
Postby SPy vs. SPy » Sat Nov 18, 2006 6:44 pm
Pheeeewwwww,
I've just retrieved your xmas card from the bin :mrgreen:
Give em a few hundred kays to get rid of the release compound before you approach any twisties with gusto, or you'll be saying those tyres are sh!T, especially if we get some rain, after that you'll have a smile you won't believe.
See ya tomorrow
SPy
AJ
Postby AJ » Sat Nov 18, 2006 7:13 pm
i have, since telling the spyster about said place, been back for a visit, only to find that ownership has changed :roll: .........however, i know the new manager & worded him up on potential MX5 club members i'll be pointing in his direction, he realised the error of his ways & will be more welcoming to the next member to price tyres at his establishment........he knows his stuff, he just needed some gentle advice :wink:
i do have another couple of contacts on the GC......... :mrgreen:
XMX5 Rogues
SPy vs. SPy
Postby SPy vs. SPy » Sat Nov 18, 2006 7:54 pm
Excellent Smithers...............
suzi
Postby suzi » Sun Nov 19, 2006 3:17 pm
Hmm - even after quick drive down to Cabarita to se how they feel I have a huge smile on my face ... road noise - what road noise? :D
Can't wait to get them on the bendy bits. Thanks for everyones words of wisdom - very happy with the purchase and shame I couldnt make todays run. :cry:
suzi
Postby suzi » Sun Nov 19, 2006 9:43 pm
almost forgot - whats with the nitrogen? they put in em??
CT
Postby CT » Mon Nov 20, 2006 6:27 am
Nitro is more stable over a longer period than just air due to the lower moisture content I believe. You can top them up with air if you need to but I think half the time it's a trick to get you going back there for repeat business. 8)
deez
Postby deez » Fri Nov 24, 2006 10:17 am
I have a question (not surprising :P) regarding alignment but didn't want to start a whole new thread. I was reading the alignment specs put up in the Tech Archive and saw that they are based on a stock standard setup.
I'm putting on 15x7\" rims and 205/50/15 tyres onto the car. Would the size and width of the rim and tyre affect how camber/castor/toe etc. should be setup compared to those specs mentioned? Or can I just walk into any Bridgestone or any sort of tyre shop and hand them those specs for alignment?
Sorry if it is a silly question...
Garry
Postby Garry » Fri Nov 24, 2006 1:04 pm
Wheel/tyre size wont affect the alignment specs as such. It may affect how the car drives after the alignment though.
Russellb
RIP Nov 2014
Postby Russellb » Fri Nov 24, 2006 2:01 pm
Garry wrote:Wheel/tyre size wont affect the alignment specs as such. It may affect how the car drives after the alignment though.
It can Effect TOE if you set TOE in MM rather than DEG As the rim Size goes up the the amount of TOE goes down But this is only a problem if your a Tight A$$e and just Aling you car on your Track tyres (15") V your road tyres (14") and expect the same were patten :shock:
My ClubmanRebuild
MX5 SE Rally car is HERE :)
