If you have aftermarket wheels...
... how nicely do your rims sit on the centre hub?
I have a set of 15's that are slightly too big for the hub and I don't want to drive around on just the 4 bolts.
Has anyone else experienced this and what kinda solution did you come up with? Hub rings?
Thanks
Thanks
- godfather of saké
Re: If you have aftermarket wheels...
atomic wrote:... how nicely do your rims sit on the centre hub?
Thanks
Yup....hub rings. Cost about $20 for a set of 4.
- godfather of saké
atomic wrote:thanks.
Is there any place you recommend? Or any wheel/tyre shop should be okay?
I think any tyre shop should be able to sell them to you. I noticed that mine were made by Mullins Wheels (ROH, etc) so they should be readily available.
- green_comet
- Car Detailing Guru
- godfather of saké
green_comet wrote:so they should be readily available
Unless you have weird sized wheels, then you will have to get a set machined up. My watanabes were a bitch i couldnt get any rings to suit the wheels.. Plenty to suit the car but not the wheels.
Really? Mu hub rings fit perfectly on my Watanabes...I vaguely recall (not 100% sure) that the outside dia of the Wats are 60mm (same as Enkei) and the inner is 53mm.
- Matty
Thanks
hub centering is only to get the wheel temporarily aligned until you do the nuts up. It's the taper on the nuts that does the real locating and load bearing.
So as long as you do the nuts up progressively and evenly you shouldn't have a problem without rings.
- green_comet
well i didnt end up finding a set of rings to fit my watanabe's. But i ended up getting my hands on the original watanabe wheel nuts which made the wheels set much more centre. My watanabe wheels have 2 tapers for the nuts to sit in, so the normal nuts i was using werent centering the wheels correctly. But the watanabe nuts solved that problem as they were shaped differently..
Babalouie wrote:atomic wrote:thanks.
Mullins = CSA
- godfather of saké
Adam_NAclubman wrote:Babalouie wrote:I noticed that mine were made by Mullins Wheels (ROH, etc) so they should be readily available.
Mullins = CSA
Yeah well what would I know, I mainly buy japanese wheels
- irwin83r
