are factory 94 clubman springs the same specs as 90 na
micksta
Postby micksta » Sun Apr 30, 2006 2:21 am
hi all
if any one knows whether 94 factory clubman spings
are the exact same specs as 90 na
i want factory ride height
thanks in advance
micksta
90 ltd edition
Postby Okibi » Sun Apr 30, 2006 1:48 pm
sorry to go a little off topic, but either set probably has a few kms on them, why aren't you looking to \"upgrade\" to a newer item (you'll feel a world of difference)?
micksta
Postby micksta » Sun Apr 30, 2006 5:14 pm
what could recommend at good price that would keep the same ride height
as stock springs
micksta
90 ltd edition
Postby Okibi » Sun Apr 30, 2006 5:18 pm
\"at a good price\" all depends on your budget.
Koni's are a great budget setup.
Re: are factory 94 clubman springs the same specs as 90 na
Postby 93_Clubman » Sun Apr 30, 2006 5:25 pm
micksta wrote:any one know whether 94 factory clubman spings are the exact same specs as 90 na? i want factory ride height
clubman springs aren't the same spec as the '90 na6 - they're firmer & apparently the bilsteins have a slightly lower spring perch meaning clubmans sit a cm or so lower - see thread below:
http://www.aus-cartalk.com/viewtopic.php?t=16845
micksta
Postby micksta » Sun Apr 30, 2006 5:37 pm
can i get koni's at stock height?
i though most of the after market springs where all lower
also thats 93 clubman
micksta
90 ltd edition
Postby Okibi » Sun Apr 30, 2006 5:45 pm
I'm not sure
The standard ones lower 35mm
http://www.koni.com/konisport/frames/main_products_1130.html
The height adjustable page only shows their lowest setting (distance from stock height)
http://www.koni.com/konisport/frames/main_products_1150.html
Sorry can't be more help :frown:
Brad
Postby Brad » Sun Apr 30, 2006 10:56 pm
Clubman is 340 front and 345 rear, wheel centre to wheel arch.
Adam_NAclubman
Postby Adam_NAclubman » Mon May 01, 2006 4:05 am
I've got Kings in my Clubman (so you'd expect it would be reasonably low with the lowered springs and the lower perches) and I havent had ANY scraping issues at all. My stock height Skyline scraped everywhere
red63sprint
Postby red63sprint » Mon May 01, 2006 2:27 pm
If its an old car the standard springs it will have dropped a bit anyway - people who lower thier car with old springs are often surprised it hasnt made much difference.
My Clubman has stock springs and shocks and has a hell of a lot of clearance...
1993 Clubman, Mx5plus roll bar
Autotechnica seats, Revalved Bilsteins
Fatcat Motorsport adjustable suspension
Espilier springs, Whiteline front bar.
Adam_NAclubman
Postby Adam_NAclubman » Mon May 01, 2006 3:17 pm
315 front, 320 rear on my car
Users browsing this forum: No registered users and 139 guests
