King springs have a nasty reputation of sagging.
Mine have sagged over the years. i ended up raising the hts on the konis.
Supension dilemma
- StanTheMan
- StanTheMan
Also check hts
measure from centre of wheel to the centre of the rear lip of fender
I'll measure it as well tonight.....
- StanTheMan
- Garry
- StanTheMan
- JBT
Slugoid wrote:Why is the drivers side lower?? With the driver in it will be even lower....wouldn't it be better if the drivers side was slightly higher?? I dunno, I'm not an automotive engineer.
The car is old, probably had one occupant (driver) most of the time and thus the springs have sagged. Mine was like that too but new springs fixed it.
- Vehicle: ND - 2
If we assume that you have King Lows in there and not replacement OEM's from King Springs, then yes the spring will look compressed.
Your problem is caused by the rebound of the spring not being dampened by the shock absorber. So a cheap Monroe w/- a King low spring will always bounce a little, even if the shock is brand new.
What you need is to upgrade the shock to something better. Minimum would be Monroe GT gas, preferably Koni or KYB - something of a better calibre than the ole cheapo shock.
- JBT
Slugoid wrote:I think I have King lows (yellow).
Colour is no guide - mine are yellow but standard ride height.
Slugoid wrote:........but could sagged springs contribute to more bouncing?
Nope, the shocks stop the bouncing - that's their job.
- sabretooth
Tons of pics of Kings + Konis here: Shocks - Koni adjustables install (NA).
On the coils of your springs, look for a small tag on the springs (take the wheel off if you have to). The model number should be there, eg KM-FL52. These will tell you which model spring you have.
