TEIN SS vs PSS9s
CT
Postby CT » Mon Jan 30, 2006 1:02 pm
bjones wrote:
roddclarke wrote:I havent run the Tein's... but your more than welcome to take my 5 for a run and see what you think..
then you need to take CT's for a spin and compare :)
MMM Might be an idea, CT you upfor that.
BJ
If we can sort out a time on the weekend it should be OK. You guys might have to venture eastwards....
Thanks for the heads up on the the miata forum thread too Matty/Okibi. That is some truly interesting info. 8)
Matty
Postby Matty » Mon Jan 30, 2006 2:34 pm
Okibi wrote:This Damper Porn Thread Matty?
yeah. why do I feel dirty watching that video?
Postby Okibi » Mon Jan 30, 2006 2:54 pm
:? i don't know ..
Benny
Postby Benny » Mon Jan 30, 2006 6:20 pm
If you've heard the PSS9's make the car tail happy, then whoever told you that had the rears set too firm, or the fronts too soft.
I generally keep mine adjusted at about half rates on the rear, and play with the fronts to adjust the car to the way I want it to be on the day.
I generally have the fronts fairly firm and this makes the car very neutral, with the option of pushing the tail out under power, if required.
Wheel control with the PSS9's is really very good and at Wakefield where other cars are bouncing all over the place, my 5 just gets down and boogies, riding over the bumps without letting a wheel become airborne, which is what shocks are SUPPOSED to do.
The Bilstiens also have a really nice ride, and with my back, that's a must have for me.
CT
Postby CT » Mon Jan 30, 2006 9:06 pm
Benny - do you run any aftermarket sway bars?
