Hey guys, I'm pretty certain that my brake rotor cover things are causing all the rattling in my car..
Are these safe to remove/bend?
Brake rotor cover things
- maxwolfie
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
- Bevan
- maxwolfie
- StanTheMan
- Russellb
- RIP Nov 2014
To remove Stone guards first remove wheel then remove brake caliper
then slip the disc off . take the dust cap off the center of the hub . undo the wheel bearing nut . slip off hub then undo 3 10mm head bolts remove
stone guard assemble in revese order . front wheel bearing torque is
123- 159 ft-lb 167 - 216 Nm should take 1/2 hr per corner
