NitroDann Engine Mount Bushing Change
Roadrunner
coyotes after you
Postby Roadrunner » Thu Apr 03, 2025 9:06 am
After years of running the poly ND engine mount I decided I was over the vibrations it caused. At certain idle rpms the seats, dash and bonnet vibrated enough to make the car slightly less pleasant than I'd like. It's ability to hold the gear stick in place mid corner on track though was worth it and the vibrations are none existent when driving at speed, but it's time to change.
I had been told the bush is moulded off a rear upper outer bush so I purchased a genuine Mazda rubber bush ($40) and I finally got time to swap it over.
Thankfully the engine mount is made so the cradle is mounted to the engine with the bush captive on the chassis side, so I only had to remove one half to access the bush. Removing the entire mount is an exercise in removing the turbo drain and brace etc which required tools I don't have due to tight access.
The centre pin of both bushes measure exactly the same but the lip on the poly bush is thicker so took up the slack between the bush lip and the tube. The rubber bush leaves about 1.5mm both sides of the tube, but the lip is hard against the thicker metal side of the mount so should be fine. You can see on the poly bush where its been compressed around the wider side section.
There shouldn't be much forward/back movement but I will keep a regular eye for any movement.
The end result:
Much much nicer. Rain drops don't dance across the bonnet anymore. I'd say it is halfway between factory rubber bushes and the ND poly bush (I have a mazdaspeed rubber drivers side mount). Time will tell how much movement of the gear stick there is when I get on it so will report back, but immediate results are positive and even just putting around the suburbs at 50kph is much smoother. Do recommend.
MeepMeep
ManiacLachy
Engaged
Re: NitroDann Engine Mount Bushing Change
Postby ManiacLachy » Thu Apr 03, 2025 9:34 am
An interesting solution, well done. Let us know how the results go, but it sounds like it's already more comfortable.
greenMachine
Postby greenMachine » Thu Apr 03, 2025 9:40 am
Interesting, thanks for posting. :BROADY:
I'll be interested in your report a few months down the track, after living with it for a while, and the rubber having settled in.
:mrgreen:
PaulF
Postby PaulF » Fri Apr 04, 2025 8:30 am
I always liked this aspect of Dann's design - you should always be able to find replacement bushings in whatever material/stiffness suits your needs.
Roadrunner
coyotes after you
Postby Roadrunner » Fri Apr 04, 2025 9:15 am
I also like the fact the bush is on the chassis side of the mount, making replacement much easier. All other mounts I've seen have the bush captive on the engine side of the mount.
Not that it's a regular change item but still, makes maintenance easier.
MeepMeep
