NA6, 1993, 175K'S WITH A WORN OUT DIFF
NA Mike
Postby NA Mike » Tue Apr 09, 2024 5:03 pm
Hi All......Help!
My NA is with a Diff repairer. My first choice is for a replacement 1.6 Diff. He's removed the Diff and tells me that the Planetary Gears are stuffed too and he hasn't yet found replacement P gears out there.
Anyone got a workable 1.6 NA Diff with good Planetary gears? Would also appreciate any potential parts or Diff specialists that I can check-in with.
Cheers.
Mike
Re: NA6, 1993, 175K'S WITH A WORN OUT DIFF
Postby 93_Clubman » Tue Apr 09, 2024 5:59 pm
Diff specialist on here is flycasta (Duane/Dwayne), but he's in Lilydale Vic, although could potentially assist with sourcing parts or steering you to source parts. PM him:
https://www.mx5cartalk.com/forum/member ... ile&u=2315
Also responses to when you posted about this in 2022 might be worth reconsidering:
viewtopic.php?f=29&t=79457&p=964894#p964894
NA Mike
Postby NA Mike » Fri Apr 12, 2024 1:57 pm
Mr. Speed Racer......Thanks for pointing me to Dwayne in Lilydale. I was about to PM him when help arrived with a couple of options too! I called my repairer and he didn't need to hear my options cause he found appropriate 1.8 gears and had the rebuilding in play. Looking forward to driving the Red Lady again.
