NB8B cranks but not starting
Posted: Mon Jan 01, 2024 7:43 pm
Hello,
Apologies if already on here though the no starting threads I have seen have many dead links in there.
Got a NB8B that won't start though its been a shed dweller for several years though I usually leave it chilling with no battery but connect to run it every now and then to run it.
Usually after leaving it on reds till all the checks are done it starts after a few cranks though not today.
What I have tried.
- LED faults though only one light then nothing (https://mx5diy.blogspot.com/2015/04/ret ... r-mx5.html)
- Took a spark plug out to check for spark, it is sparking though the plug is dry... not sure if car engines flood like mowers etc though does this indicate fuel pump/relay issue OR does the spark plug fire regardless of any crank/cam sensor fault on these?
Thanks!!!
What I have tried.
Thanks!!!
