Oil leak from gearbox filler plug
ak_perth
Postby ak_perth » Fri Nov 13, 2020 5:55 pm
Hi,
I have a small oil leak coming from the filler plug on the gearbox.
It's been very slowly leaking since I changed the gearbox oil to Redline MT-90 about a year ago, but I recall there was evidence of leakage before I changed it.
I think the plug was definitely tight enough (can't get a torque wrench on it).
Can I use a thread sealer on it to stop the leak? If so which brand/type would anyone recommend?
Thanks
Aiming Faster
Re: Oil leak from gearbox filler plug
Postby Aiming Faster » Sat Nov 14, 2020 1:49 am
Try thread tape if you want to put something around it. Notice that it's a tapered thread, so just tightening it a touch more is probably enough.
If you have access to a couple of drops of liquid thread sealant, clean the oil from the threads before applying the liquid.
RS2000
Postby RS2000 » Sat Nov 14, 2020 8:49 am
Tapered threads should have a sealant or thread tape (straight threaded plugs will have a seal or soft washer).
Any oil resistant thread sealant should do the job. Also Permatex No.3 Aviation Form A Gasket works great on threads, as does the old Stag Jointing Paste.
Postby manga_blue » Sat Nov 14, 2020 12:17 pm
There's not a crack in the housing around the hole, is there? That can happen when a tapered plug is overtightened
ak_perth
Postby ak_perth » Sat Nov 14, 2020 3:52 pm
Thanks everyone for your replies. :)
There doesn't appear to be a crack in the housing by the hole. When I tightened the plug last year I did it as much as I dared.
My plan of action is to top up the gearbox oil and then buy some "Permatex No.3 Aviation Form A Gasket" and see how that goes.
Postby manga_blue » Sun Nov 15, 2020 10:28 am
:beer:
Aiming Faster
Postby Aiming Faster » Tue Nov 17, 2020 12:07 am
The material in those threads looks like the remains of a liquid thread sealant, that'll be why it didn't leak before your oil change, using the Permatex will seal it as before.
ak_perth
Postby ak_perth » Sun Nov 29, 2020 3:32 pm
It's been a couple of weeks since I applied the "Permatex No.3 Aviation Form A Gasket" to the threads of the plug and I'm happy to report that the leak has stopped.
As you can see some of it also oozed out and created a nice bead of sealant.
Thank you RS2000 for recommending it. :beer:
