Intake length testing and results
plohl
Postby plohl » Fri Jul 03, 2020 7:40 pm
Intro
I’ve been fortunate the last month to get my car on the dyno and play around with some stuff. First thing was to test the car on E85. Fitted some bigger injectors, newer fuel pump and some pump bought E85.
The hypothesis: It won’t do anything.
As the engine is not knock limited, and my version of yoda and owner of the dyno said he’s tested it before on the engine and chassis dyno with similar builds... he was right. Back to 98.
The next thing was intake length; from the throttle body to the air filter, which snakes it was around the front of the radiator in my car.
I’ve have always had a dip in torque around 4200-5000RPM… right where I need all the torques to get out of the corners. It’s noticeable against the faster cars in class. I know some of them have at least 15whp on me at peak, and generally more power everywhere.
Aim
Find the intake length for the best torque from 4000RPM… that fits.
Hypothesis
I can gain some mid-range torque/power at WOT by varying the intake length.
Method
    1. Put car on dyno, less front bumper (really need to remember to take more photos)
    2. Turn off O2 ctrl etc
    3. Tune base line (map need a few adjustments after the e85 tests)
    4. Adjust intake length
    5. WOT ramp run, 3 – 7k RPM
    6. Compare lambda of modified intake length to aim. It is pretty easy to see an increase in engine efficiency using the lambda – even easier on the M1 where I can pause the data after the run. Example in the picture below.
    7. Repeat
    8. Once determined the best length, see if I can make it work with the bumper/ducting
    9. Set intake length
    10. Fix fuel map
Results/waffle
The below image shows a lambda trendline for each run. I’ve added a key to the image showing the variation in length from the base line. The variations were quick ballpark measurements, so could easily be ± 20-40mm. Where the lambda trend is leaner (more air) than the red baseline run, the engine efficiency has increase, and if richer (less air) it has decreased.
The following image shows compares baseline, -300mm and -250mm. -300 did give me more from 4600 to 5500RPM, but didn’t really work with the bumper and cooling ducting on, and I was hoping to get the power gains from 4000RPM. I would say the -250 run is closer to -200 than -250, however it fit and still gave the car a good improvement, even though the improvements had tapered off by 5000RPM. I should have grabbed the dyno data for the -300mm run to have really compared them.
I guess this is where the exhaust and/or cam timing would have to be altered to see if you could get some more above 5000, and keep the gains down low. I will try play with cam timing again at some point in the future.
Finally, the results…
Once we had locked in the length, I was only doing runs upto 5500 to dial in the fuel map. Compared to baseline, there was a loss in torque up to 4300, by 4600, the engine has gained 18 ftlb (19%). The gains taper off, but it still holds slightly more torque through to 5500 RPM – I’m not sure if these small gains are reliable, but generally the dyno results get worse as everything gets hotter throughout the day. There were some minor losses above 5500 and we didn’t actually do another full run to 7k, so I need to fix up the fuel map after some track testing. The final WOT run with the engine efficiency map sorted is shown below, compared to baseline.
Track testing
After a late night putting the bumper back on and packing the car, I was out at Lakeside for some testing. I could not notice this difference in power, but I did notice I was more consistently hitting a stage on the shift lights that I don’t always hit coming out of hungry (a left hander and up a hill). I even noticed this on the warmup lap.
I had dríven the car out so was using yokohamma AD08R street tyres and I have only previous used them at this track once, in February. Comparing the intake air temps, February was 31*C and the first test in June was 21*C, so a much cooler day. Previous PB was 61.1 on natsoft (timing beacon) and 60.98 from the motec. I was able to throw down some faster and very consistent laps, even whilst trying to get used to non-vacuum assisted brakes.
I have looked at the data a bit and haven’t come up with a very good strategy for quantifying the improvements seen on the dyno, but the lap times speak for themselves.
I was able to put down a 60.5s and string together multiple 60.6-60.9s laps (sectors below), and as far as I am concerned, my braking was sloppy. Not only was I very inconsistent in terms of brake pressure, I had used cheap fluid and did not have any cooling hooked up, so they would get a bit spongy after a few hot laps. Was pretty happy with the result, and I know my braking can be improved once I get used to extra pedal force required.
For reference, I raced at Lakeside in March, 30*C intake air temp, nice day, obviously track is more rubbered in racing conditions and my best time and new pb was 59.5 on Yokohamma A050s. I was consistently in the low 60s, and did a few consecutive 59s.
I returned to Lakeside 2 weeks later to get some more testing in. Same tyres, 22*C Intake air temps, same time of day = similar track conditions. I didn’t have as much clean track time, but able to get down to a 60.36 and do a few laps under my previous pb of 60.5. Still with average braking.
I very keen to head out to lakeside again soon whilst the weather is still cool with the A050s and see what I can do.
Right click on the image and click view in new tab (or similar) to enlarge it
The images above show the lap times and sector splits for the two test sessions. The i2 sector time sheet is pretty handy, I can quickly glance at it after a race and see how consistent I was by comparing the Eclectic time (sum of best sectors) vs my best lap time for that session – If there’s only a few 10ths in it, I am usually pretty happy, as this means I was fairly consistent. Another handy feature is the cell shading based of a percentage of the best sector. The purple sectors are the fastest (obviously) and blue, and shaded cells are within a percentage of the fastest sector, and set as show in last image. If I find my best time was 0.5s slower or something than the theoretical best, then I know I either had a really tough race or wasn’t very consistent, and might go looking for better explanations/excuses in the data. You can see during the second test I wasn’t as consistent but did set some faster sectors. We can see that I had a good lap 14 and it gave me a great sector 1 for lap 15, but then I slowed down for the next two sectors.
Thanks for reading if you made it this far and hopefully someone learnt something.
plohl
rascal
Re: Intake length testing and results
Postby rascal » Sat Jul 04, 2020 9:36 am
plohl wrote:First thing was to test the car on E85. Fitted some bigger injectors, newer fuel pump and some pump bought E85.
How much tweaking of the tune did you do for e85?
If engine is not knock limited then agree you won’t gain anything, but the whole point of running e85 is that you can run stupid amounts of timing that under 98 would be knock limiting.
On my car (on 98 only)it kept gaining power the more timing we threw at it, but then it came down to managing the knock. So backing it down to safer levels. With e85 you wouldn’t have that problem...
Common consensus if that there’s at least 5% gains for the taking with e85 on a nat asp motor.
plohl
Postby plohl » Sat Jul 04, 2020 2:46 pm
Lots and lots of tweaking, changed ign timing, ran leaner, ran richer. It was a good day playing around on the dyno. Putting in more fuel helped a little bit, but not enough to say you gained anything. Maybe I got a sh*t batch of fuel and it was only E50? We were going to test the fuel, but by the end of the day we forgot. I gave the fuel to my mate who ran it in his wrx - his engine didn't blow up so that's a good sign.
Going straight off the dyno numbers, I actually made 5-10 hp less over the whole range than when I had the car on the dyno 2 weeks (or 1 week) before, but we put most of that down to corrections within the software for the day. The following weekend when I went to do the intake testing, numbers were higher than the E85 tests.
My engine is 11:1 and others running similar compression have said they've gain more power from the e85, but I've always found it a bit curious, as the BP doesn't tend to be knock limited until you're at 12:1 or boosted. And given we know the details of the engines, I've always wondered where they make the extra power - are they just throwing more fuel in and essentially using the fuel to cool the intake charge? Do they just run more ign timing, even though they've already hit MBT?
It would be good to take my car to a professional tuner and see if he does anything different to me, but that would be an expensive endeavour just for science.
plohl
