Hi experienced ones.
I want to do a complete cooling system flush on my 2006 NC, not just a radiator flush. Does any body have any tips as to how I can flush the approx 3 litres in the cooling system held behind the thermostat.
P
NC complete cooling system flush
- Penguin
- greenMachine
Re: NC complete cooling system flush
If it is anything like an NA/NB, this will drain when you take the plug out of the bottom of the rad? So when you re-fill, you will re-fill the block too, and by some definitions, you have 'flushed' the complete cooling system. What do you want removed that will not be removed this way?
I assume you are using 'coolant', not water in the system. In which case corrosion should be non-existent, and there should be minimal crap in the system, and I would expect that would come out with the old coolant.
You could remove the thermostat, and stick a hose down there, but again, I wonder what you think you are fixing - what is the problem here?
- Penguin
That has been my experience with cleaning out cooling systems in the distant past, I am just getting back into being a backyard mechanic after a break. Hey when I sed to work on cars a bit there were no ECU's to speak of. The most complex car I worker on had a Bosch K jetronic fuel injection system. My reading on the www re the NC is that only about 4 to 5 litres of the 7.5 litres on the cooling system will drain when simply opening the drain plug on a cold engine. eg http://www.mx5scotland.co.uk/board2/viewtopic.php?t=15598
Was making sure that I was not missing something as I want to make sure that I only have to do this once to minimise the mixing of coolants.
Penguin wrote:only about 4 to 5 litres of the 7.5 litres on the cooling system will drain when simply opening the drain plug
I don't know NC's, but I've had cars like that. Some cars have a drain plug low down on the block.
I would refill with demineralised water & cooling system flush, & run up to full temp. Drain & refill with demin. water & coolant.
It's a time consuming process, but if you remove thermostat & flush with a hose you will be left with 3L of 'tap' water & all it's minerals.
On second thoughts, do the flush run with demineralised water only.
- Vehicle: Non MX-5
That is what i do. Dump the rad. Fill with water. Run again for a bit. Dump rad again. Refill with your coolent of perference.
- Penguin
Thanks - I will give it a go - may do two runs with distilled water as I think I am on original coolant.
- Custardtart
Done my NC coolant about 6 times in the last year. It’s just one drain plug, easy. Takes about 5 litres of coolant.
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
