Page 1 of 2
Idle speed issue NA 1.6
Posted: Mon Jan 06, 2020 11:46 am
by Purfler
I’d be grateful for advice before I do anything invasive.
The car: NA 1.6 LE. Unmodified engine 235KM
Problem:
Intermittent failure to idle when coming to a stop. On one occasion, in the garage, it would crank but not start. (I have been unable to replicate this).
What I’ve done:
Testing of the idle speed control valve (ISC) as set out here: https://www.miata.net/garage/isc.html, but not yet removed either the ISC or the air valve (AV). Using a jumper between TEN and GND causes the idle to drop dramatically, but not quite stall. I have used a little Subaru upper engine cleaner into the ISC, but no great improvement.
Questions:
1. Should I remove and blank off the AV as suggested by Miata.net to eliminate that as a possibility?
2. Should I put more cleaner into the ISC, or
3. Remove and clean the ISC, or
4. Cut to the chase and replace the ISC?
Many thanks for any advice, thoughts or experiences.
Tim
Re: Idle speed issue NA 1.6
Posted: Mon Jan 06, 2020 11:55 am
by bruce
Spark plug leads.
Posted: Mon Jan 06, 2020 12:13 pm
by Purfler
Thanks Bruce. I just tested them with a meter, all in spec.
Regards,
Tim
Posted: Mon Jan 06, 2020 12:16 pm
by bruce
It's a common issue, especially if the original leads (or a lot of age on them). They would test in spec even if faulty as you say it is an intermittent issue.
Posted: Mon Jan 06, 2020 12:20 pm
by Purfler
Thanks again. They are only a couple of years old, but I'll try putting the old ones back (they were working fine, the change was preventative - which might turn out to be a bit ironic)
Regards,
Tim
Posted: Tue Jan 07, 2020 12:19 pm
by 93_Clubman
Tim, have look at the following:
http://mx5cartalk.com/forum/viewtopic.php?t=60434
viewtopic.php?f=18&t=73272
Btw, Gladiator on here had a very persistent problem with his old NA6, which took a while to fix after trying many, many things. Think it was idle related & ultimately tracked to something intake manifold & immediate surrounds related.
Posted: Tue Jan 07, 2020 2:34 pm
by slomo
If you have idle droop, the engine is warm and runs well but the idle drops (near stall or occasionally stalls) when coming to a stop say at traffic lights then check the clutch activation switch at the clutch pedal. There is a bluish coloured plug that the white pin of the switch comes in contact with.
This plug is brittle and can break and fall out. The clutch switch is there to send a signal to the ecu that the clutch is being disengaged and for the engine to run in idle mode. Common problem, had it with both my cars.
Posted: Sun Jan 12, 2020 2:57 pm
by Purfler
Sorry for the delay in replying and thanking. Have OS house guests and have had very little time to get to the car.
Haven't replaced the leads yet, new set on its way. In the meantime slomo's description fits my problem, many thanks. This is what it looks like: Image
Inserted link isn't working in preview, this is the link: https://photos.app.goo.gl/ze5PPzcRuuMYN2yS8
I will put in a plug and see how it goes.
Not that it matters, but any thoughts on why it is designed this way?
Regards and thanks again to all.
Tim
Posted: Mon Jan 13, 2020 12:19 pm
by 93_Clubman
Tim, below are pics just taken of the clutch switch in my 1993 NA8. From your pic, yours appears to be missing the white seat base or collar:
More detail here:
http://mx5cartalk.com/forum/viewtopic.php?t=71780
Posted: Mon Jan 13, 2020 8:53 pm
by project.r.racing
If you are jumping under the dash to replace the rubber stopper on the clutch. I'd suggest doing the same for the brake pedal.
Posted: Tue Jan 14, 2020 2:22 pm
by Purfler
Many thanks again for the replies. I have not taken "after" photo but I inserted a plastic plug - like one used to secure trim. It fills the hole but does not have the thickness of yours. Is that an original part?
I just test drove the car and the idle problem has not recurred. I have now done three things that might have solved the issue, singly or together:
1. inserted plug in clutch switch
2. new plug leads
3. used small amount of cleaner in the idle control valve.
The clutch switch was definitely faulty, but who knows for how long. The old leads tested OK, but if it was an intermittent fault I'd probably never isolate it until they completely failed.
Hopefully the issue is resolved now, some days of driving will confirm.
Thanks again for the advice.
Regards,
Tim
PS- Now my back has recovered I'll have a look at the brake pedal.
Posted: Tue Jan 14, 2020 5:51 pm
by Purfler
PPS - just took the driver's side floormat out to give it a clean and found the crumbled remains of the original plug. I see how thick the striker plate was and mine is much thinner. Does not seem to have effected anything even though it must change the timing of the signal change to the ecu.
I cannot help but wonder why the plastic striker plate. Would have been easier and cheaper to have just used the folded steel that it fits in.
Tim
Posted: Wed Jan 15, 2020 11:57 am
by 93_Clubman
Purfler wrote:It fills the hole but does not have the thickness of yours. Is that an original part?
Yeah, it's the original part. A white plastic replacement tap washer looks like it would also do the job, be a bit thicker, & appear almost original.
Posted: Wed Jan 15, 2020 3:33 pm
by project.r.racing
When the one on my brake pedal failed. I found a piece of ply in the same width and glue it on. Lasted 4 years. 50 laps of lakeside. Numerous motorkhanas.
Posted: Wed Jan 15, 2020 4:51 pm
by slomo
The clutch switch is on/off for signal to ecu.
Not using the bluish plug may alter the timing of the signal change slightly.
If using trim plug instead of OEM, you may have to adjust the switch position, but only if the problem of idle droop reappears.
Also glueing a small disc of say hard rubber, the same thickness as the OEM plug onto the trim plug will do.
