WTB / NEUTRAL SWITCH FOR SE/NB8B GEARBOX
jezman
Postby jezman » Tue Mar 19, 2019 5:30 pm
Needing the neutral switch for the 6 speed, hard to find and 3 week wait from Mazda.
Please ring Phil 0419 25 30 14 if you have one to sell ............
Wakefield. SMSP GP: SMSP South: SMSP North: SMSP Brabham: Baskerville: MX5 heaven ! Symmons Plains: Winton: Sandown. Phillip Island (wow)
SuperMazdaKart
Re: WTB / NEUTRAL SWITCH FOR SE/NB8B GEARBOX
Postby SuperMazdaKart » Thu Mar 21, 2019 10:21 pm
I recently just did a replacement one of those for my Mazda Familia GT-R. I gather there's no listed aftermarket equivalent for yours in the parts catalogues?
In the end what I did for mine was try a reversing switch sensor as the neutral sensor. From a same era other Mazda. All I had to do was cut off the wiring plug from the original sensor, attach to new sensor & add an extra spacer washer to make the push-in ball the same length (though looked about the same anyway).
It wouldn't surprise me if the reverse sensor is actually the same as neutral sensor for yours. If you can find out the thread size & whether the original is open/close circuit when in neutral would useful for matching up to a replacement.
What symptoms is your car showing? Mine was mainly Idle surging.
jezman
Postby jezman » Fri Mar 22, 2019 8:40 am
Thanks for the info. Reverse light switches are apparently scarce too.
My problem is oil leaking through the switch somehow, thought is was the gasket/washer at first but it's not.
Just have to wait for Mazda to deliver ...................
Tony
Postby Tony » Sat Mar 23, 2019 12:18 pm
jezman wrote:My problem is oil leaking through the switch somehow, thought is was the gasket/washer at first but it's not.
Phil, mine did the same. I cleaned it all up with spray on brake cleaner and then immediately sealed it up with a couple of dabs of silicone. It's worked a treat ever since.
'09 NC2
Users browsing this forum: Google [Bot] and 5 guests
