Hi Guys, Just completed the new wiring harness, for the Elite 750, engine was started on a base map and ready for the dyno.
Engine specs; Track only BP4W, standard internals. Has a 4-1 exhaust, 610 injectors and runs solely on E85. That's it for now.
QUESTION; I was going to throw some new plugs in it before the dyno tune.
Any recommendations? eg standard, iridium, hotter, colder???
Plugs for E85
- Vehicle: MX5 Locost
- beavis
- Vehicle: NB8B - Turbo
Re: Plugs for E85
I run NGK BKR7E (turbocharged vehicle)
Probably better to go BKR6E or BKR5E for non turbo.
Re: Plugs for E85
Not e85, but I'm using Iridium plugs and found they helped cold start and reduced the chance of flooding back when I had the Adaptronic.
Apparently the narrow almost needle like tip helps it spark under non-ideal conditions.
Of course, a better ECU and better tuner would have been more help at the car not flooding.....
I'd talk to the tuner, ask what the recommend/prefer, since they'll presumably have done it before on other cars and have likely seen a lot more setups that work/dont work.
- StanTheMan
Re: Plugs for E85
I used a hotter one for NA exclusive on E85
I read somewhere that to take advantage of the timing a hotter plug on NA is better......
unsure of any scientific proof either way
- plohl
Re: Plugs for E85
+1 what beavis said!beavis wrote:I run NGK BKR7E (turbocharged vehicle)
In most the NA race motors we'll run a BKR8E-11 (the 11 is just the gap, 1.1mm). These are too cold to run around on the street, so I swap between the 5s and the 8s.
With a standard bottom end though, 5s or 6s will likely be fine.
Don't spend money on fancy plugs, the NGKS are great value for money, and will costs around $5 each. If you decide to run the 8s, I have found the best place to get them is sparesbox.
Stan, you don't get too much of a gain in ign timing with a standard engine and e85, as most of the map isn't knock limited. You get a bit of a bump from the higher octane.
plohl
plohl
- NitroDann
Re: Plugs for E85
If you dont put 6s in Ill do it when I tune it.
With a 0.8mm gap.
Sounds like it's close, cya soon mate.
With a 0.8mm gap.
Re: Plugs for E85
NitroDann wrote:If you dont put 6s in Ill do it when I tune it.
With a 0.8mm gap.
Thanks to all your advise guys.
Dann, yes we are very close, i'll gap some BKR6E to .8mm and put them in.
Talk soon mate
