Hi,
my 2002 Mk2.5 is making a short, loud, high pitched whistling sound when rapidly taking the foot off the accelerator.
It only occurs at higher revs, is independent of whether or not the clutch pedal is depressed and it only occurs when the aircon is on at the time.
Any ideas?
Sent from my iPhone using Tapatalk Pro
Whistling sound when taking foot off accelerator
Re: Whistling sound when taking foot off accelerator
I'd suggest aircon belt.
Otherwise, one of the bearings in the pulleys etc related to the aircon.
Mine has a weird whistly noise during revs, but that's just a floppy bearing in one of the idler pulleys.
- Custardtart
Someone snuck into your garage and fitted a turbo?
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
Aircon belts checked- all okay. Not worm our, good tension.
Still not sure what this could be.
The weird thing is that it only happens at high revs >5000/min
- bruce
- Vehicle: NA8 - Turbo
Maybe the other belt is worn? As said, maybe aircon bearings.
It's unlikely we're gonna solve this one.
Some ECUs switch off the A/C compressor under heavy acceleration (saves power loss to compressor), as you back off from a rev, ECU turns it back on. It may be the magnetic clutch grabbing which causes the belt or clutch to make the noise??
