Mikey here again - the muppet that always seems to cause himself problems
I. CANNOT. Stop. This damn car. From overheating!!!
This is going to be big write up so I'll try to summarize as much as possible but please ANY help at all, ANY ideas at all I'll take. I simply cannot figure this one out; neither can 3 mechanics, neither can my mechanically inclined friends and family.
=== CAR HISTORY AND SYMPTOMS ===
Owned the car for about 2 years. Started overheating around February this year. It won't overheat if it's running from cold and not dríven. As soon as it's dríven at any speed for a minute or more and then comes into stop-start traffic or just sits at idle again, it WILL overheat. It will overheat faster if I'm moving through stop-start traffic. It will cool down if I'm cruising in 4th and 5th gears going 70km/h+ and it will also cool down if I'm going downhill doing 50km/h+ and sitting in 3rd or higher. I'll 95% of the time have the heater and fan on max, A/C off, and this will slow the overheating down but not stop it.
I've been driving it almost daily since then and I naturally try to minimize how often it gets hot but most days it will get to 12 or 1 o'clock or more. On bad days, sh*t traffic and the like, it'll get up to 2o'clock and right up to the H. Not good. I was concerned I've ruined my head gasket and softened my head but we've run a CO2 test, read on.
SO! What's been done since this started happening?
Attempt No. 1 : First thing I did was flush and change the coolant. No effect.
Attempt No. 2 : I then assumed it was the radiator since it was rather old and I went to town. This was March/April likely. It's now got an oversize Mishimoto aluminium radiator with the matching slim fan shroud. All wired correctly and working. I replaced the thermostat, flushed it again and put new coolant in it. I replaced all of the hoses except 2. First was the one of the heater hoses at the back of the engine - too hard. Second one was one going out the back of the throttle body and under the intake manifold - again too hard.
Attempt No. 3 : I noticed the car was leaking coolant very very minutely and so I tightened all the clamps and drove it for another month or so. Wasn't convinced that I'd done it 'properly' so I dropped the coolant, took the hoses off, sanded and smoothed the lips of the steel pipes to ensure a proper seal/seat and put it all back together, flushed it, burped it for an hour and still NOTHING. No more leaks though so that was grand. This was October.
Attempt No. 4 : This was completed last night. I met a mechanic just down the road from me 2 weeks ago and started chatting to him. Top bloke and genuinely cares about doing things once and doing them right. He offered me his shop, his hoist, help and supervision. He ran some diagnostics and some proper man hours simply trying to figure it out with me. He also had a auto-electrician/cooling expert with him on the day. Checked the head gasket doing a CO2 test. Came back all clear. He discovered that one heater hose was rock hard and hot, and the other was cool and not under pressure. Originally he said it was a blocked heater core. Moving on we took the cap off the radiator and left the car running. They noticed there was no flow in the coolant whilst idling but while revving there was. He also said there was 'tiny metal shavings' in the coolant. Something similar to seal-up. Diagnostic: screwed water pump. SO! Over the next three days with his help I changed; the water pump, timing belt, idler pully, tensioner pully. Dropped and changed the coolant. Checked the rocker cover for leaks, nothing. Put a new gasket in and resealed it. Checked all the hoses again. Basically gave the entire engine bay a checkover and clean in addition to a major service. Kicked it over and drove it to work this morning... AND I F**KING OVERHEATED AGAIN.
Someone please just put me out of my misery
Last few important things that I think are unrelated but worth mentioning. In the process of Attempt No.4 we've broken the thermostat temperature sensor. We tried gluing it with a 2-stage silica solution but it's definitely gone so I have to replace it. I know it's dead because as soon as you turn the car to ON but it's not running the fans will kick on. This never happened prior to Attempt No.4. And lastly, in relation to Attempt No.3; I was fiddling with my throttle body briefly while I did this in an attempt to fix my low idle (was sitting at 750-800 hot) I turned the flat bung using a flathead screw driver underneath the rubber plug on the the throttlebody. Since I've done this the car won't start warm unless I prime the fuel pump 3 times. I know this is probably a whole another drama but unless it's related to the overheating it's not my concern at the moment. The car starts with a little bit of care and it runs fine.
